rtdavide
hey guys,
don't know if this is the right place to ask this, but here goes.
vista ultimate 32 is my main OS now, but i have the Win 7 64 bit on a separate drive. pretty much everything works except for my mustek scanner. this is a pretty much necessary piece of equipment for my work, being a tabloid sized scanner that is actually affordable. But it doesn't look like mustek has any intention of making 64 bit drivers for it.
someone suggested setting up a Virtual Machine and maybe running the scanner from there. I've done some poking around to research the whole idea of a VM, but i'm not sure if it would actually work with drivers or not.
would i be able to set up a VM on my win 7 64 bit and run 32 bit scanner drivers from there?
thanks for any info.
Setting up a virtual machine (VM) to run your 32-bit scanner on a 64-bit operating system like Windows 7 is indeed a potential solution to your driver compatibility issue. Here's a breakdown of how you can approach this:
Steps to Set Up a VM for Running 32-bit Scanner Drivers:​
  • Choose a Virtualization Software: You will need virtualization software like VirtualBox, VMware Workstation, or Hyper-V to create and run a virtual machine.
  • Create a Virtual Machine: Install the virtualization software and create a new VM. Make sure to allocate sufficient resources like RAM, CPU cores, and storage for the VM.
  • Install a 32-bit OS: In the VM, install a 32-bit operating system that is compatible with your scanner...
  • Install a 32-bit OS: In the VM, install a 32-bit operating system that is compatible with your scanner and its drivers.
  • Install Scanner Drivers: Once the 32-bit OS is set up, install the scanner drivers within the virtual machine.
  • Connect the Scanner to the VM: To use the scanner within the VM, you will need to establish a connection between the VM and the scanner. Some virtualization software allows USB pass-through for devices like scanners.
  • Test Scanner: After setting up the drivers and connecting the scanner, test it within the VM to ensure it functions correctly.
Considerations:​
  • Driver Support: Verify that the scanner's 32-bit drivers are compatible with the 32-bit OS you install in the VM.
  • Hardware Compatibility: Ensure that your virtualization software supports USB pass-through for the scanner to work seamlessly.
  • Performance Impact: Running a VM will consume additional system resources, so consider the impact on your system's performance. By following these steps, you should be able to set up a virtual environment where you can run your scanner using 32-bit drivers. This approach allows you to bridge the driver incompatibility between your scanner and the 64-bit Win 7 OS. If you need more detailed instructions on setting up a VM or require assistance with any specific virtualization software, feel free to ask!
