MatRennie
Hopefully someone out there cna help me out here!
I have an alienware M9700 gaming laptop. Win 7 64 bit installs beautifully but I am having a nightmare finding a driver which will get my 'Multimedia Audio Controller' working. The support from alienware was literally none existant and I cannot see from my documentation exactly WHAT driver I need to get! I have tried downloading nearly 1.5 gigs worth of different drivers and as yet none have worked.
I am getting really frustrated here so ANY help will be awesome!
My system specs are attached via dxdiag. If there is any other info needed I will happily supply it! :)
m9700 Win7 x64 drivers
Hope this will help you:
Go to support.alienware.com and search in the Knowledge Base the following:
Answer ID 6051 - Drivers installation sequence for Aurora m9700 mobile systems
thanks,
fedehernan
thanks,
