Does the order of RAM sticks matter? I am new to hardware. if I have 6 slots 1 GB sticks won't natter I guess. But what If the sticks are 1 and 2 GB? My PC appears to be dual channel where two sticks fit in each module(Block with 2 slots).
The thread discusses whether the order and pairing of RAM sticks matter for optimal performance, especially in dual-channel configurations. Respondents suggest matching RAM sizes and speeds and often recommend installing matching pairs into color-coded slots to ensure proper dual-channel setup. The original poster confirms they used the color coding method successfully on their Dell XPS 8300, indicating a positive conclusion to their inquiry.
If there are two slots then add to slot 1 first then 2 or two sticks. It's better if they are the same size sticks 2GB and 2Gb or 4GB and 4GB etc but it will still run with mismatched sticks. Keep them the same speed or the board will downclock to the slower speed. If it's 4 slots it's better to add them to every other slot before pairing them up because each pair should have a separate DMA controller
- Joined
- Jul 4, 2015
- Messages
- 8,994
Normally the slots have got different colors. E.g. there are two blue slots and two black slots. The modules that are inserted into the slots of the same color should ideally be the same. If you got two different pairs insert one pair into the slots of color x and the other pair into the slots of color y.
