seekermeister
Honorable Member
I need to replace a fan in my HTPC, but I have a couple of questions. first, how is a fluid ball bearing different from a regular ball bearing fan? Secondly, one fan caught my eye:
I'm not as interested in the high speed of the fan as I am the thickness (38mm). Am I right in thinking that a thicker fan will produce more CFM than a thin fan at the same speed?
I intend to use this for the blow hole fan atop the HTPC in my bedroom, and since I keep it running continuously, I definitely do not want a high noise level, and I don't know that high CFM is actually a good thing for a fan of this sort, because at high CFM, it might disturb the air flow pattern adversely. But since this fan cost twice as much as most other fans of it's size, my interest in it is just in having the ability to experiment with different speed settings.
Blow hole fans are great, but as you note, being right there, noise can be a factor and fan noise in HTPCs is always objectionable. So you are right, you want a very quiet fan in that location. And you are also correct that you do not want to disrupt the desired front...
seekermeister
Honorable Member
Yes, I wasn't thinking about the price of a big screen or sophisticated speaker system. The screen on mine is only 25", but that is bigger than most of the TVs that I ever owned, so I'm happy with it. As far as the speakers go, I would like to have a better system than I do, but in the complex where I live the walls are paper thin, and I have very cranky neighbors that will almost beat holes in the wall if I get even slightly loud on the volume, so I either use a couple of small 2.0 speakers near my bed, or a Sennheiser headset, if I want a greater volume.
Digerati
Microsoft MVP
Yeah, neighbors and loud music don't mix very well. But if loud enough, you can't hear them banging on the walls!!! ;)
Just for the record, loudness is NOT an indication or measure of quality (fidelity). The best speakers sound great at low volume levels as well as high. Almost any speaker can thump thump loud enough to disturb neighbors. The trick is to produce a SPL (sound pressure level) of 110 plus dB @ 18-20Hz so it vibrates all the dishes and windows in their house, but they are unable to determine what is causing it, or what it is they think they "feel". :)
