After re-installing my OS I noticed that I had lost a massive amount space. It automatically set up a c drive with approximately 100 gigs of space and an additional d drive with only 9 or 10 gigs of space. I looked in the disk management settings console and noticed multiple entries with a disk 0 with 5 and 6 as partitions with little space in them and an unallocated space with over 1750 gigs that is positioned all the way to the right in the bottom view area. I try to make a new simple volume which is all the options that are available to me with I choose that space or right click on it and always get the error message the extent is less than the minimum. I have changed the minimum disk pace to 1 and got the same error. I changed it to much higher number and get the same message. I have also changed the simple volume to much lower and much higher and still received the same message. I think I have seen in the pop up messages something about it being a virtual hard drive but it is always listed in the disk management console and never unmounts or detaches when I log off or restart so I do not think it is a virtual hard. I have never set one up and tried reformatting and re-installing the OS and that space always comes up unallocated and unformattable. I have tried many disk partitioning programs- like all of them and nothing has worked. In some I have tried to increase the size of the other drives to gobble up the unused space and it never allows me. I have tried to shrink that space in order to use it in the c or d drive and I can't. I do not know what to do. And I know at one time before a re-install I had use of the space and it was included in the c drive. I want to make one drive- the c drive with all the storage. Attached are screenshots of the menus and error messages and the about page for my pc. Can anyone help?
Shooter D
Shooter D
