M4niAc
I have two disk drives. One that uses SATA and an old IDE drive. I was only able to install Windows 7 via the SATA drive and had to disconect the IDE drive to even install.
After installing; I hook my IDE drive back up. Windows will detect it, but the drive is unusable right now.
Does anyone have any solutions?
Windows 7 does not seem to like ide drives. When i installed it with my ide drive it worked but took forever to install, And after it was installed it took forever to boot. How i solved the problem was to put an ide to sata convertor on the hardrive and it now boot's right up. Go figure. i don't know if anyone else has tried that but it worked for me. By the way it was on a dfi lanparty DK pk35 series board but i assume that it would be the same for any other board that you tried it with. Try that and see what happens and good luck.:)
busydog
If it is detected in Disk Management, I'd try formatting (or re-formatting) if you can't assign a drive letter and use it.
lokie
