cybercore
- Joined
- Jul 7, 2009
- Messages
- 15,626
- Thread Author
- #1
Product name: Danamics LMX
€280
built around Danamics' groundbreaking liquid metal technology featuring the unique electromagnetic pump which circulates the liquid metal in the LMX system without the use of moving parts. This noiseless propulsion is obtained by creating electromagnetic forces directly inside the liquid metal, causing it to move.
(27 December 2009)
Danamics LMX Liquid Metal Cooler Review | Reviews - Clunk.org.uk
http://www.hexus.net/content/item.php?item=16157
€280
- Heat sink material: Nickel Plated Aluminium
- Tubing Material: Nickel Plated Copper
- Housing Material: Plastic
- RoHS Compliant: Yes
- Sockets Supported: All AMD Processors For Socket AM2/AM2+/AM3. All Intel Processors For Socket 775/1156/1366.
- Dimensions: (LXHXD) 158.2 X 170.5 X 90MM (Heat Sink Only).
- Motherboard Clearance Height: 30MM
- Weight: 1180G (Heat Sink Only).
- Fan Compatibility: 120mm Fan
- Dimensions: (LXHXD) 120 X 120 X 25 MM
- Speed: 2000 RPM
- Airflow: 75.7 CFM
- Noise Level, 1M xyz axes avg: 21.8 DBA
- Noise Level, 1m z axis: 28.6 DBA
- Operating Voltage: 6.0 - 14.0V
- Current Draw: 0.30 A
- Power Consumption: 3.60W
- Bearings: FDB, Fluid Dynamic Bearings
- Power Consumption: <1W
- Magnet Type: Neodymium Block Magnet
- Gauss Rating, 0.05m xyz axis: 12 Gauss (0.0012 Tesla)
(27 December 2009)
