The thread revolves around a user seeking advice on selecting a reliable 750-watt modular power supply and considering a new PC case with an integrated PSU. Experts recommend SeaSonic as a trusted brand and suggest opting for full tower cases with good airflow and cable management, exemplified by a user's recommended setup. The discussion highlights troubleshooting power issues, with the conclusion pointing toward a potential faulty PSU, rather than the motherboard or CPU, based on testing results.
seekermeister
Honorable Member
I need to order a new power supply for one of my computers, and I have a pretty good idea of what to look for, except in one respect...brand. I ask this question because of problems I've had in the past with two well known brands...Antec and Gigabyte, which I don't want to repeat anything similar with.
I'm familiar with the major brands, at least by name, but is there one in particular that stands out from the others in ~750 watt modular unit? Anything new that has come out in the last 3-4 years that I should know about.
The only way to physically check is to get a known good working PSU...check it with the tester to verify the tester works. Then install the known good working PSU into your system to see if it boots up. If both check out, then you'll know it's your PSU.
seekermeister
Honorable Member
Thread Author #22
Obviously, there are a lot of other people looking for the same thing. It is the best socket 939 board ever made.
seekermeister
Honorable Member
Thread Author #23
I think that I fixed it. I re-connected the 4 pin section of the ATX cable, while leaving the 20 pin section alone, and for some reason it now turns on and off as it should. I hope that it doesn't decide to do something else.
Jimbo22
You mean to tell me...you didn't have them both plug in...
seekermeister
Honorable Member
Thread Author #25
No, that is not what I said. The word that I used was RE-CONNECTED, not connected. I simply unplugged it and then plugged in back in again.
Jimbo22
ah...gotcha...it could have been simply a loose connection. Let's keep our fingers crossed.
seekermeister
Honorable Member
Thread Author #27
One would think that, but I plugged and replugged it so many times that it couldn't have just been a loose connection...unless the cable had a broken wire in it, but if so I can't reproduce the problem now.
