vkamble
Hi
I have windows 7 on my laptop and using a wifi network in my home. I see the unidentified connection error very frequently and if i try to dignose the error the system get hangs and have to shut down otherwise it does not resoponds.
Please tell me how can i solve the issue?
Did you update the network drivers off the manufacturers website? If so try un-installing and then re-installing again. If it still keeps showing a yellow question mark it could the that the hardware is failing.
Alongside MSE I always run Malwarebytes too. If MSE misses anything then this will pick it up. Please download and run:
Malwarebytes : Free anti-malware download
This page from Microsoft has handy hints too:
http://windows.microsoft.com/en-US/...reless-network-connection-problems-in-windows
vkamble
Thanks Link Removed for quick response. I tried your both the options but still the issue is not resolved. if you need any more information the do let me know.
May I ask if this problem started recently or have you been struggling with it a while? Perhaps system restore might get you back to a point where all was good?
vkamble
Thanks again for quick reply. Now i have restored the system but the issue is not resolved and the system hangs when trying to diagnose the internet connection. it is showing me error "Problem with the wireless adapter or access point" wereas i have another machine which has windows xp installed and is working fine without any issues. My windows 7 machine also works for the first time when i restart the machine. And after some time i am able to connect to the internet. When i lose internet connection it does not show me any network connections in my internet connections available list. The network connections goes so frequently that it is very difficult to work on this system. Sometime it shows yellow icon besides my Network Adaptor 802.11n and when i clicked update driver it shows the drivers are updated.
vkamble
Hi Kemical.. i tried again installing the malwarebytes but there are no issues after running it. i tried the microsoft sites too but my phone wifi works properly and other laptop works fine with the wifi connection.
When i started my laptop it worked for an hour. It showd me all the wifi network connections and i manully connected to network and it work for an hour and again the problem started. suddenly my internet connection lost and when i clicked on dignose connection it become nonresponsive and hanged. Now there is no yellow sign on network adapter.
Hmm... It's weird that it'll work for a time and then not.. Try opening up device manager and then right click on your network device and choose properties. Look for power management and then uncheck 'Allow the computer to turn off this device to save power'.
vkamble
I just tired power management option too.. Again the ssame case, it worked for some time and lost my internet. After that all my wifi connections are gone. it does not show any connection. Link Removed
