spypsycho
so, I have a 5.1 sound system, specifically the logitech X-540 and an external USB sound card that is supposed to allow me proper 5.1 surround. When I try the configuration on windows all speakers correspond when I click them and work just fine but when i play music or any sound, the sound only comes out of the Front right and left speakers unless I enable matrix mode which is not true surround though. any ideas on how to solve this???
It seems like you're experiencing an issue with your 5.1 sound system where only the front right and left speakers are producing sound instead of the full 5.1 surround sound setup. This could be due to your system not properly recognizing the 5.1 configuration or the audio settings needing adjustment. Here are some steps you can take to troubleshoot and potentially resolve this issue:
Troubleshooting Steps:​
  • Check Sound Settings:
  • Right-click on the sound icon in the taskbar and select "Open Sound settings."
  • Under the "Choose your output device" section, ensure that the correct sound card with 5.1 surround support is selected.
  • Configure Speaker Setup:
  • Go to "Sound Control Panel" by right-clicking the...
  • Go to "Sound Control Panel" by right-clicking the sound icon and selecting "Sounds."
  • Under the "Playback" tab, right-click on your sound card and select "Configure Speakers."
  • Choose the "5.1 Surround" option and follow the setup instructions.
  • Update Audio Drivers:
  • Ensure that your audio drivers are up to date. You can update them manually from the device manager or download the latest drivers from the manufacturer's website.
  • Test Audio Output:
  • Use the "Test" button in the Speaker Setup to check if each speaker is producing sound during the configuration process.
  • Disable Exclusive Mode:
  • In the "Sound Control Panel," under your sound card's properties, go to the "Advanced" tab and uncheck "Allow applications to take exclusive control of this device."
  • Check Media Player Settings:
  • Some media players have their audio settings that may override the system settings. Check the audio configuration within your media player to ensure 5.1 surround sound is selected.
  • Reset Enhancements:
  • In the sound card properties, under the "Enhancements" tab, disable any enhancements that might interfere with the 5.1 surround sound output.
  • Check Matrix Mode Settings:
  • Verify that there are no specific settings related to matrix mode that could be affecting the surround sound output. By following these steps, you should be able to troubleshoot and resolve the issue with your 5.1 surround sound system behaving incorrectly. If the issue persists, it might be worth checking for any specific settings related to your USB sound card or seeking further assistance from the manufacturer's support.
