The user is experiencing issues with an ActiveX DLL-based program running on 32-bit Windows 7, despite it working on 64-bit systems, and is seeking an emulator or solution to make ActiveX behave as on the 64-bit version. Later, they suggest the problem might stem from Windows issues rather than a bit-version difference and inquire about methods for diagnosing or repairing ActiveX-related problems. The overall sentiment indicates troubleshooting confusion and a desire for solutions to get the activeX component working properly on 32-bit Windows.
jsampson1945
I have a proprietary program with a programmable interface consisting of an ActiveX DLL. It works properly on a 64-bit version of Windows 7 but not on a 32-bit version. Is there such a thing as an emulator for 32-bit Windows that would make ActiveX work as though it were the 64-bit version?
Perhaps it is not a 64-bit vs 32-bit problem, but just that there is something wrong with Windows. I suppose with frequent updates being installed it must be surprising that Windows goes on working at all. What is the best way of diagnosing and repairing an ActiveX problem?
jsampson1945
Thread Author #2
