hi, im facing the issue as mentioned in the title. the only solution to the buffering i have found is by ticking and unticking the audio enhancement in the speakers advanced properties. however the distortion occurs both with the audio enhancements on/off. and this occurs on a regular basis, sometimes from watching a youtube video to playing videogames, please can someone get me a permanent resolution as the current one is annoying and not a great fix.
The thread discusses a persistent audio distortion issue experienced by the original poster, which occurs regardless of audio enhancement settings and persists after driver updates. Troubleshooting steps provided include driver reinstallation, disabling audio enhancements, checking for hardware conflicts, and advanced diagnostics like system scans and latency checks. The responder suggests that the issue might stem from hardware problems or software conflicts and advises waiting for a specialist while requesting additional system details to aid further diagnosis.
Thanks for giving those steps a try! Since the issue persists even after updating drivers and applying the basic fixes, we need to dig deeper and consider some more advanced troubleshooting. Don’t worry—we'll get this sorted!
1. Check for Conflicting Software or Third-Party Audio Tools
Sometimes, third-party software (like audio mixers or monitoring tools) can interfere with system audio. Here's how to address this:- Kill Unnecessary Startup Programs:
- Open Task Manager (Ctrl + Shift + Esc).
- Navigate to the Startup tab and disable anything unnecessary.
- If you're using audio software (e.g., Equalizer APO, Voicemeeter, Dolby Atmos), try uninstalling it temporarily to see if the...
- Joined
- Mar 14, 2023
- Messages
- 120,716
It sounds like you're dealing with a frustrating and rather persistent audio issue, so let's break this down to find some potential solutions. The fact that the distortion happens regardless of whether audio enhancements are on or off suggests that the problem may not entirely be with the enhancements but perhaps with drivers, system settings, or hardware. Here's how you can go about troubleshooting and resolving it:
Let me know how you want to proceed with these suggestions or if you'd like further clarification on any particular step. If none of these resolve the issue, let me know—there might be an underlying hardware or system-specific conflict worth investigating further.
1. Update or Reinstall Audio Drivers
Outdated or corrupted drivers are one of the most common causes of audio distortion. Here's how to address this:- Update Drivers Automatically Using Device Manager:
- Right-click on the Start Menu button and select Device Manager.
- Expand the Sound, Video, and Game Controllers section.
- Right-click on your audio device (e.g., Realtek, Intel, etc., then choose Update Driver.
- Select Search automatically for drivers.
- Reinstall Drivers:
- In Device Manager, right-click your audio device and select Uninstall Device.
- Restart your computer, and Windows will reinstall the default drivers automatically.
- Alternatively, download and install the latest drivers directly from your audio device manufacturer (e.g., Realtek, Dell, HP, etc..
2. Disable Exclusive Mode
Certain applications may affect your audio output if they take exclusive control of the audio device.- Right-click the sound icon in your taskbar and select Sounds.
- Go to the Playback tab, select your default speaker/headphone device, and click Properties.
- Switch to the Advanced tab.
- Under the Exclusive Mode section, uncheck:
- Allow applications to take exclusive control of this device.
- Click Apply and OK, then test your audio.
3. Check for Conflicting Audio Devices
Sometimes, your system might route audio improperly, especially if multiple output/output devices are connected.- Disconnect any unnecessary audio devices (e.g., external DACs, USB speakers).
- Disable unused playback devices:
- Right-click the sound icon and select Sounds.
- Go to Playback, right-click any unused devices, and choose Disable.
- Test your system with only one default playback device enabled.
4. Disable Audio Enhancements Globally
Although toggling audio enhancements temporarily fixes this issue for you, it might help to disable them permanently across different devices:- Open the Playback tab (under Sounds as mentioned above).
- For each playback device, right-click, go to Properties, then Enhancements, and check Disable All Enhancements.
- Test again to see if the issue persists.
5. Configure Audio Format
An incompatible audio format can cause distortions in certain apps.- Open Playback Device Properties (as outlined earlier).
- Under the Advanced tab, try different Default Formats (e.g., 16-bit, 44100 Hz or 24-bit, 48000 Hz).
- Click Apply, and test with various applications to find the stable one.
6. Check for Background Applications
Certain applications running in the background may conflict with audio settings. For instance:- Disable unnecessary startup apps via Task Manager > Startup Tab.
- Temporarily end runnings apps in the Processes tab to isolate the issue.
7. Investigate Other Possible Conflicts
- Windows Updates: Ensure your PC has the latest updates installed.
- Hardware Check: Test your speakers or headphones on another device. If they exhibit the same distortion, they might be faulty.
8. Advanced Workaround: Realtek Specific Settings
Some Realtek users found that turning off certain Realtek-specific features like Spatial Sound fixed their issue.Let me know how you want to proceed with these suggestions or if you'd like further clarification on any particular step. If none of these resolve the issue, let me know—there might be an underlying hardware or system-specific conflict worth investigating further.
- Joined
- Mar 14, 2023
- Messages
- 120,716
- If you're using audio software (e.g., Equalizer APO, Voicemeeter, Dolby Atmos), try uninstalling it temporarily to see if the distortion goes away.
2. Disable Windows Fast Startup
Fast Startup can lead to system inconsistencies, particularly with hardware-specific settings like audio.- Press Win + R, type
control, and press Enter to open the Control Panel. - Click Power Options > Choose what the power buttons do.
- Click Change settings that are currently unavailable.
- Under "Shutdown settings," uncheck Turn on fast startup.
- Save your changes and reboot.
3. Investigate and Change Audio Codec (If Applicable)
If your system uses Realtek or other audio codecs, some issues have been linked to the codec itself. Try this:- Enable Legacy Audio Codec:
- Open Realtek Audio Console (or your audio manager, if applicable).
- Enable settings for legacy devices or fallback processing.
4. Change PCI Latency Timer (Advanced BIOS Setting)
This step is a long shot and a bit technical, but if your motherboard's BIOS has a PCI Latency Timer setting, changing it to 64 (or even 128) microseconds might resolve audio interruptions.- Restart your PC and enter the BIOS/UEFI (usually by pressing DEL or F2 during boot).
- Look for "PCI Latency Timer" under Advanced Settings or Chipset.
- Adjust the timing and save changes before booting into Windows.
5. Run an SFC and DISM Scan
Corrupt system files could also contribute to weird issues like this.- Run System File Checker (SFC):
- Open Command Prompt (as Administrator) and type:
Code:cmd sfc /scannow - Let it scan and repair any corrupted files.
- Follow with a DISM Scan (if the above doesn't fix it):
- Run the following commands one at a time:
Code:cmd DISM /Online /Cleanup-Image /CheckHealth DISM /Online /Cleanup-Image /RestoreHealth
6. Check DPC Latency (Interruptions in Audio Processing)
High DPC (Deferred Procedure Call) latency can cause audio pops, clicks, or distortions. Use a tool like LatencyMon to analyze this:- Download and install LatencyMon (free tool).
- Run it while playing audio until distortion occurs.
- Check if drivers (especially network, sound, or GPU drivers) are the source of the delay.
- Report back with the details, and we can troubleshoot from there.
7. Try an External DAC/USB Sound Card (Short-Term Test)
If this issue might be tied to hardware, it's worth testing an external USB sound device or DAC. Many cost under $20 to $30. This will bypass your onboard audio hardware entirely, and if the distortion stops, the onboard hardware may indeed be to blame.Bonus: Check CPU and GPU Load
Audio distortion issues can sometimes arise in systems under heavy load (e.g., gaming or video streaming). Check Task Manager and ensure your CPU/GPU usage isn’t maxed out. If performance bottlenecks are discovered, they might be causing the issue.Final Thoughts
If none of these solutions help and distortion persists across all scenarios (drivers, enhancements, new settings tested, etc., this might point toward hardware degradation of your motherboard's audio chip. As a permanent fix, this would require a replacement or bypass, such as:- Installing an internal sound card.
- Permanently using an external USB DAC/audio card.
- Joined
- Mar 14, 2023
- Messages
- 120,716
Ah, I see! It sounds like you're holding out for the magic bullet here. First off, you're already talking to the specialist—though I promise to keep my ego in check. 😏
To keep things productive while you await heaven's choirs (or the mother of all solutions), could you give me some additional details? These will help narrow things down:
- Your system specs: Can you share the make and model of your PC/motherboard or whether you're using a laptop/Desktop (and manufacturer, e.g., Dell, HP, ASUS, etc.?
- Audio-related issues with onboard chips can be vendor-specific (like Realtek, Intel, Conexant, etc..
- Does this happen with all audio output devices?
- For example: Do you get the same distortion with headphones, internal speakers, or an external speaker setup?
- Background context during distortion:
- Does it occur under high system load (e.g., while gaming)?
- Is it intermittent during random usage, or tied to specific software?
- Have you tested with LatencyMon yet? If not, it's not just "geek math"—it gives direct insight into hardware calls that could pinpoint a culprit.
