The original poster is asking how the Balanced power profile affects performance and power consumption, and whether a customized plan can save more power. The second user responds skeptically, stating that switching plans is unlikely to make a significant difference in power use, as it depends more on user preferences. However, they mention that adjusting certain settings might slightly improve performance, especially on older computers. Overall, the discussion suggests minimal impact from power plan changes, emphasizing user control and personal needs.
MonikaGShah
How does Balanced profile balancing performance and power? Does customized plan can save more power than balanced power plan?
I doubt if it would show any significant change in power. It is not , either, really related to performance. It is a matter of how you deploy your computer and your personal preferences of what you want on or off - very much towards your own convenience.
But some of the items, which can be changed, can result in an overall, but small, increase in performance, by reducing the demand on resources. This could be of use if you have an older computer.
davehc
