The original poster is experiencing an issue where their Ethernet-connected computer is recognizing the network as the WiFi extender rather than their main network, Home 5. ChatGPT suggests adjusting network priorities, changing adapter settings, and configuring the network connection order to ensure the computer connects via Home 5 instead of the extender. Overall, the thread offers troubleshooting steps aimed at resolving network identification and connection preferences.
Devilstompa
So I have 2 connections, Home 5 and a wifi extender in my office. The computer is not wifi and dosent hook up to the wifi extender box. It's still coming up as wifi extender on my ethernet not wifi. I would like it to be home 5 on the ethernet.
To ensure that your computer is connecting via the desired network (Home 5) instead of the WiFi extender when using Ethernet, you can follow these steps: 1. Network Settings: - Right-click on the network icon in the system tray and select "Open Network & Internet settings." - Go to "Ethernet" on the left sidebar. - Click on the network profile associated with the Home 5 network and prioritize it. 2. Change Adapter Options: - Press Windows Key + R, type "ncpa.cpl," and press Enter to open Network Connections. - Right-click on the Ethernet adapter and choose "Properties." - In the list of items, make sure the Home 5 network is at the top of the list for priority. 3. Network Prioritization: - If you see both networks...
To ensure that your computer is connecting via the desired network (Home 5) instead of the WiFi extender when using Ethernet, you can follow these steps: 1. Network Settings: - Right-click on the network icon in the system tray and select "Open Network & Internet settings." - Go to "Ethernet" on the left sidebar. - Click on the network profile associated with the Home 5 network and prioritize it. 2. Change Adapter Options: - Press Windows Key + R, type "ncpa.cpl," and press Enter to open Network Connections. - Right-click on the Ethernet adapter and choose "Properties." - In the list of items, make sure the Home 5 network is at the top of the list for priority. 3. Network Prioritization: - If you see both networks (Home 5 and WiFi extender) on the Ethernet connection, set Home 5 as the default or higher priority. 4. Connection Order Adjustment: - In the Network Connections window, search for Advanced > Advanced Settings. - Set the network connection priority so that Home 5 is at the top of the list. 5. Network Reset: - Disable other network connections temporarily while ensuring only Home 5 is active for Ethernet. 6. Specific Network Configuration: - Check your router settings to ensure the proper configuration for Home 5 network recognition. By prioritizing and ensuring that the Home 5 network configuration is established correctly in the network settings, you can direct your computer to connect via the desired connection even while using Ethernet.
