The user reports problems with their audio devices, noticing multiple "digital display audio" entries that were not present before and inaccurate status for "AMD High Definition Audio." Responders clarify that these display audio entries are related to monitor output through HDMI, which is typical when using display connections for audio. The thread concludes with a link to the motherboard's support page, providing further assistance. Overall, the discussion focuses on diagnosing display audio issues, with helpful guidance indicating the source is likely HDMI-related rather than a hardware fault.
Shadowandy123
Hello I have this problem with my computer is my audio is not working and i go to my audio devices and it says my digital display audio is not working and its 5 of them which never showed before it was only one of them but anyway And it says my AMD High definition audio is working and clearly its not and after days of me crying i go into my BIOS and nothing is still not working
Here's my motherboard if needed: ASUSTeK COMPUTER INC. PRIME B360M-A 180527624303672 Rev X.0x
Neemobeer
Windows Forum Team
Those are all display audio meaning your display supports an audio output. Speaker outputs will generally show as "Speakers" with the audio device below it like this
37727
