The thread discusses concerns about a large cache file repeatedly regenerating, potentially slowing the system, with the original poster seeking ways to disable caching and expressing a dislike for Windows 8.1 compared to Windows 7. Respondents suggest running malware scans and tools like CCleaner to clear cache, and clarify that Windows 7 is not available for free or capable of being converted directly from Windows 8.1 unless under specific licensing agreements. Overall, the discussion focuses on troubleshooting cache issues and expressing dissatisfaction with Windows 8.1.
cvc
ok when I open the file its huge,,,11k files,,,i delete them all and in 5 minutes there are thousands back...doesn't this slow my system down ?? How do I disable caching ?? I see it in "internet options" file...
Thank you
Have you tried using something like ccleaner or the disk clean app?
That should clear the cache.
Windows 7 isn't free and you cannot change operating systems unless there was already a deal in place with the store you bought from (sometimes called a downgrade)
cvc
Thread Author #3
Humm...ok...I have seen others complaining about this with Win8.1 too....ill run this an see...is windows defender a decent anti-virus?...thank you
cvc
Thread Author #4
Can I chg this. System to Windows 7 for free??? I liked 7 and this 8.1 I don't like
