A user with a Sony Vaio running Windows Vista 32-bit seeks help retrieving iCloud Control Panel version 2.1.3 after accidentally deleting it, as Apple no longer provides it. Responders advise upgrading from Vista due to its end-of-life status and potential compatibility issues, but the original poster expresses satisfaction with Vista and just wants to recover the deleted software. Overall, the thread centers on the challenges of running outdated software and the importance of updating to newer operating systems for better support and security.
kzach
Hi All,
I'm really hoping someone here can help me.I have a Sony Vaio Laptop ,which I love !!.It's os is Vista 32 service pack 2 ..
I deleted icloud control panel and photostream by mistake and now I can't find it anywhere. I need the 2.1.3 version of icloud control panel and Apple says it does'nt exit anymore. I did find it a few years ago but I can't remember where.
My family all have iphones and i love the way if i take a phot it goes straight to my laptop.
Can someone olease send it to me or tell me where to get it.TIA.
Reagrds
Apple is notorious at not making older versions available, so unless you can find it on some third party file sharing site you're probably out of luck
Neemobeer
Windows Forum Team
You should seriously considering upgrading your OS since Vista has been out of support for years and new exploits are created all the time. That plus the fact that software vendors have dropped support for it as well.
kzach
Thread Author #4
Why do you still use Windows Vista?
Do you not know it reached the end of life several years ago?
It still works perfectly for me and i like it.It does all I require it to do.I asked for help in this matter not criticism !!!
kzach
Thread Author #5
Ilike it it does all i need it to do
livix07
Honorable Member
There is no criticism, I just wanted to help you take into consideration that your problem with iCloud might be caused exactly by the fact that you are using an outdated version of Windows.
kzach
Thread Author #7
No Offence meant liviix07. I didnt have a problem with icloud.It worked perfectly with vista.It's just I deleted it by accident and i cant find ithat version 2.1.3 anywhere
livix07
Honorable Member
How long ago did you delete it?
You can use Link Removed to try to recover it from your disk.
kzach
Thread Author #9
About 2 weeks ago.Thanks Ill try it.The link won't work though. Its ok i found it Ill try it and see if it helps.Thanks
Neemobeer
Windows Forum Team
Like I said because the OS is out of support currently available versions of software are less likely to work on Vista as well.
kzach
Thread Author #11
The thing is ,which I don't understand.is that if I could find version 2.1.3 or 2.1.1 it would work perfectly as it was doing.
Neemobeer
Windows Forum Team
kzach
Thread Author #13
Thats what I was hoping for.I was hoping someone would tell me where i'd get it.
I found 2.1.1 version on torrents but people had stopped seedingso I could'nt download it.
