The thread discusses a user's issue with playback errors in Windows Media Player when trying to view videos from a body cam on a Windows 7 system. Despite installing various codecs, including the K-Lite Codec Pack, some files still won't play properly, with only the first five files functioning correctly. The overall sentiment indicates ongoing frustration and difficulty in resolving media playback problems despite attempts to update codecs.
wills
I have a body cam which I use whilst on the scooter. Problem is that when I replay the files some play ok and the all of a sudden I get Windows Media Player encountered a problem while playing the file. So why is this happening ? downloaded media codexs, DivX and Xvid and installed them but did not help.
Had about 12 files on the 32gb sd card this morning, 5 played ok no problem but the other 7 no way.
Any advice would be much appreciated, thank you.
wills
wills
Thread Author #4
Hi, many thanks for your advice. Have downloaded the K codes however had to un install a few other codex files. I installed K-lite codec pack called standard, installed same but still no joy. The first 5 files are ok to watch but anything after that I get a screen shown below.
hope the attachment helps. thank you, Wills.
An image from 'AVI replays'. Warning in MPC-HC showing failure to render pins due to missing codecs or filters.
