The original poster is experiencing issues with their Logitech headset microphone not being detected in Windows 7, despite working in Windows XP and the sound drivers being up to date. A respondent suggests setting up the microphone through the Windows 7 configuration, but the original poster reports that this process isn't working as the microphone isn't picking up sound and they cannot proceed with the setup. Overall, the thread indicates a troubleshooting attempt with a negative outcome so far.
taokaenoi
I'm unable to use my Logitech microphone headset at all. I have Realtek sound drivers and windows says it's updated to the latest already, i've also played around with the settings abit too, increasing boost levels, etc. etc. the headset i'm able to use for windows xp though! not windows 7. when i go to the sound options, it detects the microphone put in, it just doesnt pick up sound at all. i bought the computer with windows 7 just recently.
thanks!
I think you have to setup the headset in windows 7 first before you can use them. Click start orb and then type in "set up microphone" with out the quotes. Then just follow prompts. Once done it confirms that the head set is ready to be used with this computer.
Jimbo22
taokaenoi
Thread Author #3
yeah its not working, its not picking up the sound and letting me press "next"
