The thread discusses a Windows 7 user experiencing issues with Aero themes being disabled following a October 2018 update, with troubleshooting efforts including service checks, system scans, and registry changes. The problem was ultimately traced to a quarantined file by antivirus software, which was restored, temporarily resolving the issue. The user later confirmed that the latest Windows update in November 2018 fixed the problem, and they seek help in updating the original post's title.
Username2Taken
Hello, since the last Window 7 update (october 10th) on my computer, aero themes are no longer working and are "greyed out" as shown on the picture below (i can't click on them or select them):
An image from '[NOT solved anymore] Problems with transparency and other aero effects'. Windows 7 French interface showing Aero theme settings, troubleshooting, services, cmd info, and registry edits.
I have already tried the following steps to attempt to fix this problem, without success:
1)clicking on "troubleshoot problems with transparency and other aero effects":
it detected the following problems:
_the actual theme doesn't support aero -> sure, but i'm unable to pick one that does in personalize
_Desktop Window Manager Session Manager is disabled
But when i go to services.msc, the manager is displayed as started and configured to start automatically. Restarting it didn't solve the problem. The same goes for Themes.
Its configurations as shown in cmd are as follows:
Could there be a problem here?
2) I looked at this thread, my problem didn't come from there (see picture above," dependencies" in themes are empty)
3) This is an interesting one, i followed the steps suggested on Link Removed.
Adding the following DWORDs in HKEY_CURRENT_USER\Software\Microsoft\Windows\DWM did originally solve my problem
But after rebooting my PC on the following day, the problem was back and the dwords where (and are) still here. Maybe this can somehow help someone to figure the problme out?
Thank you in advance for your answers.
Edit: for some reason it won't let me submit this post to the 'official' microsoft q&a forum, does anyone know why?
(finally) SOLVED: with the latest windows update (11/2018), everything went back to normal, so the problem was definitely there.
i don't seem to be able to update my oldest replies and the post title anymore, could a moderator update the title to [solved]?
Neemobeer
Windows Forum Team
That's really just controlled by the themes service. You may want to try running some repair commands if restarting the service isn't working.
sfc /scannow
and
chkdsk c: /R
Username2Taken
Thread Author #3
sfc /scannow
and
chkdsk c: /R
The file checker didn't find anything:
An image from '[NOT solved anymore] Problems with transparency and other aero effects'. Windows command prompt running sfc /scannow with no integrity violations found.
Checkdisk repaired some files in the USN journal, but the problem is still here.
Username2Taken
Thread Author #5
Have you tried updating the gpu driver?
It is up to date.
After a bit of research, i finally found the real source of the problem: my paranoid antivirus quarantined the Desktop Window Manager Session Manager:
An image from '[NOT solved anymore] Problems with transparency and other aero effects'. Avira Free Antivirus shows 71 quarantined files with various threats detected and one file cleaned.
This may also explain why the troubleshooting wizard detected the manager as disabled in spite of the fact of it being theoretically activated in services.
After restoring it and rebooting my PC everything went back to normal.
Thanks for your help.
Username2Taken
Thread Author #6
NOPE, after another rebooting everything isn't working again, and the Windows Manager is not blocked by my antivirus now.
I don't really now what to do next, any ideas?
Username2Taken
Thread Author #7
