mgerber
Every time I wake my computer up from sleep mode a program (Coral Paintshop Pro X4) keeps starting up. My O/S is Windows 7 Ultimate. Not sure where to stop this from happening. Any suggestions would be appreciated.
To stop a program from automatically starting up when you wake your computer from sleep mode in Windows 7 Ultimate, you can follow these steps:
  • Using System Configuration (msconfig):
  • Press Windows Key + R to open the Run dialog box.
  • Type "msconfig" and press Enter.
  • In the System Configuration window, go to the Startup tab.
  • Look for the entry related to "Coral Paintshop Pro X4" or any related entry that may be starting the program.
  • Uncheck the box next to the entry.
  • Click Apply and then OK.
  • Restart your computer to apply the changes.
  • Using Task Manager:
  • Right-click on the taskbar and select Task Manager.
  • Go to the...
  • Go to the Startup tab.
  • Right-click on the entry and select Disable.
  • Close Task Manager.
  • Using Registry Editor:
  • Type "regedit" and press Enter to open the Registry Editor.
  • Navigate to the following key:
     HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run
  • Look for any entry related to "Coral Paintshop Pro X4" in the right pane and delete it if found.
  • Close the Registry Editor. These methods should help you prevent Coral Paintshop Pro X4 from starting up automatically when you wake your computer from sleep mode. Remember to be cautious when making changes in the System Configuration or Registry Editor.
