teak
It looks like my Software isn't a Illegal Copy. What I did was go to Start, than Computer, than Activation. I seen a Code there and there is a in put area. The Code Input comes up, and you read in the Product Code. Press Next. If the code is a illegal Copy the Software will say so.
"You are a Victim of an Illegal Windows"
But the Code From my brown sticker went through and worked. The progess bar wil say "Activated" After Authentication.
There is another method which is some kind of phone method. I have to look that one up.
This deffinately works on Window 7.
teak :p
It seems like you successfully activated your Windows software using a valid product key, which means your copy is genuine. The process you described involves accessing the activation section through the Control Panel, entering the product key from the sticker, and following the prompts to activate the software.
If you encounter the message "You are a Victim of an Illegal Windows," that would indicate that the software has identified the product key as not genuine or pirated.
For Windows 7, activation can also be done via phone, where you would have to follow specific steps provided during the activation process to activate Windows over the phone.
It's great to hear that your activation process went smoothly and your Windows software is...
It's great to hear that your activation process went smoothly and your Windows software is now activated. If you have any more questions or need assistance with anything else related to Windows, feel free to ask! 😊
