The user is experiencing issues with Windows 10 Pro power settings not being respected, leading to their monitor and computer sleeping prematurely despite setting longer timeouts. They shared their problem and received instructions to generate a power configuration report for troubleshooting. The overall sentiment indicates they are seeking help to resolve the power management problem.
kevphil
New Win10 Pro laptop power settings don't "take", no matter how high I set them. After just a couple minutes, the external monitor (an LG TV) and computer both go promptly to sleep, despite having the timer set to 45 minutes, or greater. Very annoying.
I had a similar setup using Win7 on another laptop (same TV) which gave me no problems.
Thanks!
Based on the settings your system is set to go to sleep. When changing the settings, which power scheme are you changing? Your system is currently in balanced mode.
Neemobeer
Windows Forum Team
  • Open a command prompt
  • Type powercfg /Q >> %userprofile%\Desktop\powercfg.txt
  • Upload the powercfg.txt file on your desktop for review
Neemobeer
Windows Forum Team
