The thread concerns Windows 11 USB recovery media: the initial issue was traced to using the CD/DVD-only “system repair disc” tool instead of the USB recovery creation tool, which the original poster then found and used. A later contributor reported that two formatted USB drives appeared in File Explorer but not the recovery wizard on a Dell; troubleshooting suggestions included connecting directly, testing with system-file backup unchecked, and sharing read-only disk details, with no resolution posted yet. Overall, the tone is helpful and reassuring, and the original poster was apologetic about the mix-up.
Zevik83
I have used the same USB Flash on this Lenovo laptop before to create a Recovery Disk. Now wanting to recreate after some months. Win11 Home now demands a CD/DVD drive and does not see the USB Flash as an option. I restarted after doing a System Image on an external HDD in case that would help but no change. Surely this has to be a Win11 problem - or am I missing something?
This usually happens when you’re in the wrong Windows wizard.
Why Windows is asking for a CD/DVD drive​
If you opened Control Panel → Backup and Restore (Windows 7) and clicked “Create a system repair disc”, that tool only creates a CD/DVD. It will not offer a USB flash drive, so it appears as if Windows “demands” an optical drive.
What you want instead (USB): “Create a recovery drive”​
Do this on Windows 11:
  • Plug in the USB flash drive.
  • Click Start and type: Create a recovery drive
  • Open Create a recovery drive (it may ask for admin permission).
  • If you see the checkbox “Back up system files to the recovery drive”, leave it checked (recommended)...
  • If you see the checkbox “Back up system files to the recovery drive”, leave it checked (recommended), then Next.
  • Select your USB drive → Next → Create.
Note: This will erase the USB stick.
If you actually want a bootable Windows installer USB (also USB, not DVD)​
Use the Microsoft Media Creation Tool to create an installation USB (also works as repair media). This is separate from “Recovery Drive”.
If the Recovery Drive tool still doesn’t list your USB​
Then it’s a detection/format issue. Check these quick items:
  • Does the USB show up in File Explorer and Disk Management?
  • Is it large enough? (Often needs 16 GB+ if you include system files.)
  • If it’s weirdly partitioned, reformat it (Disk Management → right‑click USB partition → Format). If it won’t behave, we may need to “wipe and recreate” the partition (I’ll give GUI steps; no registry editing).
If you tell me exactly which screen you’re on (or paste a screenshot) and whether you clicked “Create a system repair disc” vs “Create a recovery drive”, I’ll point you to the correct path immediately.
Zevik83
Thread Author #3
I am ashamed. At 84 years old, my memory is so bad! Of course I used the bootable creation tool before, and the app sits happily on my desktop. It is working away now. So sorry to have bothered you.
No bother at all, Zevik83 — that’s exactly the kind of mix‑up Windows encourages with its two different “repair” tools.
While it’s running, here are two quick “sanity checks” so you don’t get surprised later:
1) The USB will be erased
  • The Recovery Drive / Media Creation process wipes the flash drive. That’s normal.
2) Test it once
  • When it finishes, reboot and use the one‑time boot menu (often F12 on many PCs, Lenovo may be Novo button / F12) and confirm the USB is seen and boots to the recovery/setup screen.
If you run into any message like “USB not bootable” or it doesn’t show in the boot menu, tell me:
  • the laptop model (Ideapad 3 exact model if you can),
  • whether the USB is UEFI booting or Legacy,
    and I’ll give the exact BIOS/boot settings to check.
arvipat
Member
USB Flash drives (32 GB or 128 GB) are not recognized during the Recovery Drive process on my Dell 15 Win11 notebook.
Its dialog box searches for media when i attach either 32 GB or 128 GB, but fails to recognize either. Screenshot attachment is disabled here as my account is new.
I have selected the Back Up System Files option every time.
Both the 32 GB and 128 GB flash drives are formatted, and both show up in File Explorer.
Welcome to the forum, arvipat! No worries about screenshots being disabled on a new account—plain-text output from a quick check will actually tell us even more than a screenshot.
Testing both a 32 GB and a 128 GB drive while confirming both appear in File Explorer is very helpful: it confirms basic USB connectivity works and rules out raw capacity being too small on the 128 GB stick.
Likely Hypotheses to Test​
  • Hypothesis 1 (Removable vs. Fixed drive classification): The Windows RecoveryDrive.exe tool strictly requires drives that report to Windows as Removable Media. Some flash drives—or flash drives connected through a USB-C hub, dock, or SD/microSD adapter—report as a Fixed / Local Disk (External hard disk media), which File Explorer opens normally but RecoveryDrive.exe ignores.
  • Hypothesis 2 (Partition layout, read-only flag, or USB storage policy): An existing multi-partition table, a write-protection flag, BitLocker To Go policy, or a storage filter driver on the Dell notebook may prevent RecoveryDrive.exe from qualifying the media.
  • Hypothesis 3 (System-file staging issue): When Back up system files to the recovery drive is selected, Windows inspects your recovery image alongside scanning for drives; testing whether the drive list populates with that box unchecked separates a USB detection issue from a system-image staging issue.
Part 1: Quick Non-Destructive Checks​
  1. Unplug any USB hubs, docks, or card readers, and plug the 32 GB flash drive directly into a built-in USB port on your Dell 15 before opening the tool.
  2. Click Start, type Create a recovery drive, and open Create a recovery drive.
  3. As a diagnostic test only, uncheck Back up system files to the recovery drive and click Next.
  4. Check whether either USB drive appears on the selection screen, then click Cancel so nothing is written to or erased from your drive.
Part 2: Read-Only PowerShell Diagnostic (No Screenshot Needed)​
These commands are strictly read-only and do not modify your system or USB drives. Any destructive step (such as wiping, repartitioning, or creating recovery media on a USB drive) needs review of this output first—and be sure to back up any important files on those USB drives beforehand.
  1. Plug both the 32 GB and 128 GB USB flash drives directly into your Dell notebook.
  2. Right-click the Start button and select Terminal (or PowerShell).
  3. Copy and paste the following command block, press Enter, and paste the text output into your reply:
Get-Disk | Select-Object Number, FriendlyName, BusType, PartitionStyle, IsReadOnly, @{Name='SizeGB';Expression={[math]::Round($_.Size/1GB,1)}}
Get-CimInstance Win32_DiskDrive | Select-Object Index, Model, InterfaceType, MediaType, Partitions
Get-Volume | Select-Object DriveLetter, FileSystemLabel, FileSystem, DriveType, HealthStatus, @{Name='SizeGB';Expression={[math]::Round($_.Size/1GB,1)}}
Additional Details to Share​
  • What is the exact wording shown in the wizard after it finishes searching (for example, Connect a USB drive vs. We can't create a recovery drive on this PC)?
  • Did the USB drive appear in the list during Part 1 when Back up system files to the recovery drive was unchecked?
  • Are these standard one-piece USB-A/USB-C thumb drives, or microSD cards inside a USB adapter?
arvipat
Member
Part 1:
1. The 1-piece USB thumb drives connected directly to my Dell 15 notebook do appear when i leave the Back up system files to the recovery drive option unchecked.
2. The USB thumb drive is not detected if i check the option to Back up system files to the recovery drive.
Part 2:
Windows PowerShell 5.1
Copyright (C) Microsoft Corporation. All rights reserved.
PS C:\Users\drapa> Get-Disk | Select-Object Number, FriendlyName, BusType, PartitionStyle, IsReadOnly, @{Name='SizeGB';Expression={[math]::Round($_.Size/1GB,1)}}
Number : 2
FriendlyName : USB SanDisk 3.2Gen1
BusType : USB
PartitionStyle : MBR
IsReadOnly : False
SizeGB : 114.6
Number : 0
FriendlyName : NVMe OM8TAP4-AD0 KDI 512GB
BusType : NVMe
PartitionStyle : GPT
IsReadOnly : False
SizeGB : 476.9
Number : 1
FriendlyName : hp x705w
BusType : USB
IsReadOnly : False
SizeGB : 14.5
PS C:\Users\drapa> Get-CimInstance Win32_DiskDrive | Select-Object Index, Model, InterfaceType, MediaType, Partitions
Index : 1
Model : hp x705w USB Device
InterfaceType : USB
MediaType : Removable Media
Partitions : 1
Index : 2
Model : USB SanDisk 3.2Gen1 SCSI Disk Device
InterfaceType : SCSI
Partitions : 1
Index : 0
Model : NVMe OM8TAP4-AD0 KDI 512GB
MediaType : Fixed hard disk media
Partitions : 5
PS C:\Users\drapa> Get-Volume | Select-Object DriveLetter, FileSystemLabel, FileSystem, DriveType, HealthStatus, @{Name='SizeGB';Expression={[math]::Round($_.Size/1GB,1)}}
Thank you for running those tests, arvipat—that output narrows the problem down immediately.
What Your Results Confirm​
  • USB hardware and port hypotheses withdrawn: Both flash drives report as writable (IsReadOnly : False), single-partition Removable Media, and Part 1 confirms RecoveryDrive.exe detects them normally when Back up system files to the recovery drive is unchecked. Your USB ports, drivers, and thumb drives are working properly.
  • Why the HP drive (hp x705w) is excluded: Get-Disk shows Disk 1 has a physical capacity of 14.5 GB (a 16 GB nominal drive rather than 32 GB). When system files are included on Windows 11, RecoveryDrive.exe commonly requires 32 GB on Dell systems, so the HP stick is too small for that mode.
  • Hypothesis for why the 128 GB SanDisk (114.6 GB) is also rejected: RecoveryDrive.exe formats the target USB stick as a FAT32 partition capped at 32 GB, even on 64 GB or 128 GB drives. On Dell Windows 11 notebooks (note Disk 0 has 5 partitions), factory provisioning files stored under C:\Recovery\OEM can push the staged recovery payload past that 32 GB limit—or WinRE staging may fail—causing RecoveryDrive.exe to leave the USB drive list blank regardless of how large your flash drive is.
Step-by-Step: Read-Only Check of WinRE and Dell Recovery Files​
Before considering any file or partition changes (which would require reviewing this evidence first and creating a System Restore Point), let's inspect your WinRE status and C:\Recovery folder sizes with read-only commands. (Note: On your previous paste, the final Get-Volume line just needed one extra press of Enter to run.)
  1. Right-click the Start button and select Terminal (Admin) or PowerShell (Admin), then click Yes at the UAC prompt (administrator elevation is required to read reagentc and C:\Recovery).
  2. Copy and paste the following read-only commands, press Enter once more after the last line if needed, and paste the output here:
reagentc /info
Get-ChildItem -Path C:\Recovery -Recurse -Force -ErrorAction SilentlyContinue | Select-Object FullName, @{Name='SizeMB';Expression={[math]::Round($_.Length/1MB,1)}}
Get-Partition -DiskNumber 0 | Select-Object PartitionNumber, DriveLetter, Type, @{Name='SizeGB';Expression={[math]::Round($_.Size/1GB,2)}}
  1. Also let us know the exact capacity text shown on the RecoveryDrive.exe screen when Back up system files is checked (for example, The drive must be able to hold at least 32 GB... or 64 GB).
Official Alternatives That Work Right Now (Without Touching System Files)​
If your goal is simply to get reliable bootable recovery and reinstallation media made today without troubleshooting RecoveryDrive.exe, you have two supported options. Warning: Back up any files currently on the target USB flash drive first, as creating bootable recovery media erases all data on the USB stick.
  1. Option A — Dell OS Recovery Tool (Recommended for Dell notebooks): Download the Dell OS Recovery Tool from Dell Support, enter your laptop's Service Tag, and write the image to your 128 GB SanDisk drive (requires at least 16 GB). Unlike Windows' generic tool, this creates a bootable factory recovery USB tailored to your Dell 15 with Dell's preinstalled storage and Wi-Fi drivers included, bypassing the RecoveryDrive.exe FAT32 bug.
  2. Option B — Bootable WinRE USB + Separate System Backup: If you only need a bootable repair stick to access Startup Repair, System Restore, Command Prompt, or System Image Recovery, you can run Create a recovery drive on your 14.5 GB HP stick with Back up system files to the recovery drive unchecked, or use Microsoft's Windows 11 Media Creation Tool on the 128 GB SanDisk stick.
Glad to hear that worked out, arvipat! Using the Dell OS Recovery Tool is actually the cleanest solution for a Dell notebook since it includes your model's factory storage and network drivers right out of the box.
Quick Verification Steps (Recommended Before Storing It)​
To make sure you have no surprises if an emergency ever happens, do a quick, non-destructive boot check:
  1. Leave the newly created USB recovery drive plugged into your Dell 15 notebook.
  2. Click Start > Power > Restart.
  3. As soon as the Dell logo appears, tap F12 repeatedly to open the One-Time Boot Menu.
  4. Confirm that your UEFI USB drive appears under the UEFI Boot Devices list.
  5. Select the USB drive to verify it loads to the initial Dell SupportAssist OS Recovery / language selection screen, then exit/shut down without starting a reset (Warning: do not proceed past the initial menu, as running an OS recovery will overwrite your system drive).
  6. Unplug the USB stick, label it clearly with the laptop model and today's date, and store it in a safe place.
Let us know if you ever run into anything else!
arvipat
Member
Thanks, Dell recovery came up in the boot menu with the just-created Recovery Drive.
That’s good news, arvipat! The boot menu recognizing the Dell recovery USB is a useful first check.
One correction: my earlier explanation about a FAT32 limit and Dell recovery files causing the Windows Recovery Drive issue was speculation, not something your results established. I also shouldn’t have guaranteed which drivers the Dell recovery media includes. Sorry about that.
