blksith0
- Joined
- Oct 24, 2012
- Messages
- 61
OS's: Windows 10 Enterprise
I'd like to connect two different devices together via ethernet so that LAN apps behave better.
However both devices (running windows 10) are connected to the same wireless network, and I don't know how to configure a direct-lan-ethernet connection, let alone how to make this 2nd network not conflict with the 1st.
What do?
What do?
I'm not sure why you chose making these 2 networks different, but that's certainly a step in the wrong direction.
I think you'd be better server by buying a 2nd wireless router, and hook PC-#A to your old router, and PC-#B to your new router; both Wi-Fi connected. Otherwise, you'll have contention and beaconing on your Ethernet connection between the 2 PC's, even if on separate subnets!
You're PC on each subnet/wireless connection to your router will be fighting sending/receiving Ethernet packets between the NIC and the WLAN (internal or external Wi-Fi card/adapter). This is NO-BUENO!
