The thread discusses configuring two computers, one with Windows 10 Pro and the other with Windows 11 Pro, to use Ethernet for direct communication (like shared folders and remote desktop) while maintaining Wi-Fi connectivity for internet access and other network devices. The suggested solution involves adjusting network settings to prioritize Ethernet over Wi-Fi for local traffic and disabling network discovery only for the Wi-Fi network, which might limit discovery on Wi-Fi itself. The original poster then asks if it's possible to achieve this setup without disabling network discovery and file sharing over Wi-Fi for other devices on the home network.
Glebis
I am looking for guidance on how to configure the network to achieve operability as documented below. Please refer to attached diagram for clarity. Any suggestions will be much appreciated.
Computer A is running Windows 10 Pro, Computer B is running Windows 11 Pro
Both computers are connected to a WIFI router, and through that to the internet and other devices on my home network
The two computers are also connected to each other through their Ethernet interfaces.
Desired Outcome:
Use Ethernet connection when computers A and B access each other, via shared folder, remote desktop, or remote desktop cut and paste (to optimize these interactions for performance).
Have any other accesses to the internet or other devices on my home network from either computer use their respective Wifi interface
Thank you for reading!
To achieve the desired outcome, you can follow these steps:
  • Disable the network discovery and file sharing settings for the Wi-Fi network on both computers. This will prevent them from communicating with each other over Wi-Fi.
  • Connect both computers to the same Ethernet switch or router. Ensure that the Ethernet connections are established and working properly.
  • On both computers, open the Network and Sharing Center. You can do this by right-clicking the network icon in the system tray and selecting "Open Network & Internet settings." Then, click on "Change adapter options."
  • Locate the Ethernet adapter and the Wi-Fi adapter for each computer. Right-click on the Ethernet adapter and select "Properties." In the Properties...
  • Locate the Ethernet adapter and the Wi-Fi adapter for each computer. Right-click on the Ethernet adapter and select "Properties." In the Properties window, scroll down and find "Internet Protocol Version 4 (TCP/IPv4)" and select it. Click on the "Properties" button.
  • In the IPv4 properties window, click on the "Advanced" button. In the Advanced TCP/IP settings window, go to the "IP Settings" tab. Uncheck the "Automatic metric" box and enter a lower metric value, such as 10. This will prioritize the Ethernet connection over the Wi-Fi connection for local traffic.
  • Click "OK" to save the changes and close the windows. Repeat these steps for the Ethernet adapter on the other computer.
  • Now, when you access shared folders, remote desktop, or perform remote desktop cut and paste between the two computers, they will use the Ethernet connection for optimal performance.
  • For accessing the internet and other devices on your home network, the computers will automatically use their respective Wi-Fi connections.
    By following these steps, you should be able to achieve the desired outcome of using the Ethernet connection for local communication between the two computers while still using the Wi-Fi connections for internet and other network access.
Glebis
Thread Author #3
Thank you chatGPT, you are a clever robot! Is there a way to do this and preserve network discovery and file sharing with other devices on the home network through WiFi?
