Yamadron
Hello..
I am having an application that can only detect Wired Network Adapters "Realtek PCIe". Since I am using a Laptop, I am using my Wireless Adapter "Intel Wifi Link 5100 AGN" and connecting to my Wifi network.. Is there any software solution that can make some sort or bridge or virtual network that can send all packets to the Wired LAN adapter, so the application can work ??
To bridge your wireless network to a virtual wired network, you can use a feature in Windows called Internet Connection Sharing (ICS). This feature allows you to share your wireless internet connection with other devices through a wired connection. Here's how you can set it up:
Steps to Share Wireless Internet via Ethernet (ICS):​
  • Enable Internet Connection Sharing on your Wireless Connection:
  • Right-click on the network icon in the system tray and choose "Open Network & Internet settings."
  • Go to "Change adapter options."
  • Right-click on your wireless adapter (Intel Wifi Link 5100 AGN) and select "Properties."
  • Go to the "Sharing" tab and check the box that allows other network users to connect through this...
  • Go to the "Sharing" tab and check the box that allows other network users to connect through this computer's internet connection.
  • Connect the Ethernet Port:
  • Connect an Ethernet cable from your laptop's Ethernet port to the device you want to provide internet access to (the device where the application is running).
  • Configure Device Network Settings:
  • Set the device's network interface to obtain an IP address automatically (DHCP).
  • Test the Connection:
  • Check if the device is able to access the internet through your laptop.
    Note:​
  • Be cautious with ICS as it involves setting up your laptop as a gateway, which could introduce security risks if not properly configured.
  • Your wireless adapter will act as the main network adapter, and the Ethernet port will be used to share the connection.
  • Ensure that the application you are trying to use is compatible with sharing the network through ICS. By following these steps, you should be able to bridge your wireless network to a virtual wired network using Internet Connection Sharing in Windows.
