Commander_Cool
Hi, I recently began learning Office 2010 and have an Excel specific question. The thing is, when I print an Excel-file I prepared the print is real tiny, almost unreadable as if the sheet should be divided into 6 or 7 pages rather than the 3 pages that I have somehow managed to get it down to. It looks fine on the screen, but the printout...
A magnifying glass is called for to read the file unless somebody can clue me in as to what I'm doing wrong.
I'd be most hankful for any and all advice :confused: 'cause I'm at wits end, and the sooner the quicker.
It seems like you are facing an issue with printing Excel files where the printout is too small and difficult to read. This can be due to several factors, such as the page setup settings, scaling options, or print area settings in Excel. Here are a few steps you can take to address this problem: 1. Adjust Page Layout Settings: - Go to the "Page Layout" tab in Excel. - Check the page orientation (portrait or landscape) and adjust it accordingly. - Verify the size of the paper you are using under the "Size" dropdown. - Make sure the margins are set correctly to allow for a readable printout. 2. Set Print Area: - If you want to print specific parts of your sheet, you can set the print area. - Select the cells you want to print...
It seems like you are facing an issue with printing Excel files where the printout is too small and difficult to read. This can be due to several factors, such as the page setup settings, scaling options, or print area settings in Excel. Here are a few steps you can take to address this problem: 1. Adjust Page Layout Settings: - Go to the "Page Layout" tab in Excel. - Check the page orientation (portrait or landscape) and adjust it accordingly. - Verify the size of the paper you are using under the "Size" dropdown. - Make sure the margins are set correctly to allow for a readable printout. 2. Set Print Area: - If you want to print specific parts of your sheet, you can set the print area. - Select the cells you want to print. - Go to the "Page Layout" tab, click on "Print Area," and select "Set Print Area." 3. Adjust Scaling Options: - Excel provides scaling options to fit your content to a specific number of pages. - Ensure the scaling is set to "Fit Sheet on One Page" or adjust it to a suitable scale. 4. Preview Before Printing: - Use the Print Preview feature in Excel to see how the document will look before printing. - This can help you identify any potential issues with the printout. 5. Check Printer Settings: - Ensure that your printer settings are correct and suitable for the document you are printing. - Verify the paper size and type to match your Excel settings. By following these steps, you should be able to adjust the print settings in Excel to get a more readable and appropriately sized printout. If you continue to experience issues, feel free to provide more details, and I can assist you further.
