Raxan
After changing out my MB, Windows 7 Home Premium would not boot so I ran Sysprep which I got to finish. After booting, the system went through the Starting System Services, etc. process one time and rebooted now when I start up I get the Starting System Services message and then an error window "Windows could not complete the installation. To install Windows on this computer restart the installation". I am in a loop with this message appearing every time the system boots. I extracted the data from the Setup.etl file and could find no failure or error message. The last message in the file was that windeploy.exe was running. How do I find out what is wrong and get my system to boot?
It seems like you are encountering a boot loop issue after changing your motherboard in a Windows 7 Home Premium system. This issue often arises due to hardware changes that can cause Windows to require reconfiguration. Here's a step-by-step guide on how you can troubleshoot and resolve this problem: 1. Check Hardware Configuration: - Ensure that all the hardware components are properly connected, especially after changing the motherboard. - Double-check the connections for storage drives (HDD/SSD), RAM, graphics card, and other peripherals. 2. Boot into Safe Mode: - Try booting into Safe Mode to see if it allows you to access the system without the installation error. - To boot into Safe Mode, restart your computer and repeatedly press the F8 key until you see the Advanced Boot Options menu. - Select "Safe Mode" from the list and see if Windows boots successfully. 3. Use System Restore: - If you can access the system in Safe Mode, try using System Restore to revert the system back to a point before the motherboard change. - Go to Start > All Programs > Accessories > System Tools > System Restore. - Choose a restore point before the hardware change and follow the on-screen instructions. 4. Check BIOS Settings: - Verify that the BIOS settings are correctly configured for the new motherboard. - Ensure that the boot order is set to the correct drive where Windows is installed. 5. Repair Windows Installation: - Insert your Windows 7 installation disc or USB drive and boot from it. - Choose the repair option to run Startup Repair or System File Checker (SFC) to fix any corrupted system files. 6. Investigate Event Viewer: - Check the Event Viewer for any error messages that might provide more details about the installation failure. - Press Win + R, type "eventvwr.msc", and press Enter. - Look under "Windows Logs" > "System" for any critical errors or warnings. 7. Re-run Sysprep: - If Sysprep was interrupted or not completed successfully, you may need to re-run it to properly configure the system for the new hardware. - Follow the Sysprep process carefully to ensure it completes without errors. 8. Check for Driver Issues: - Ensure that all necessary drivers for the new motherboard are installed. - Update or reinstall drivers as needed, especially chipset, network, and storage drivers. By following these steps, you should be able to troubleshoot the boot loop issue and resolve the installation error that is preventing Windows from starting successfully. If you encounter any specific errors or issues during these steps, feel free to provide more details for further assistance.
