The thread discusses upgrading from a 32-bit to a 64-bit version of Windows 7. The original poster learns that switching from 32-bit to 64-bit requires a clean install and inquires if the same product key can be used, wondering if activation will be an issue. The confirmed responses indicate that the same key can be used for the 64-bit installation and that activation should proceed without problems, assuming proper installation.
nitewulf
Honorable Member
I know you can upgrade 32 bit to 64 bit using a custom install. My question though, is I installed Windows 7 32 bit using a retail upgrade disk. I've now decided I want to try 64 bit. Since the upgrade box contained 2 discs (32 & 64 bit), am I free to install the 64 bit on the same computer or would I have to buy a whole new upgrade disc set? It seems like it would let me install the 64 bit which would have it's own key, but I want to make sure.
JessicaD
You cannot "upgrade" a 32-bit OS to 64-bit -- a custom install is a clean install for all practical purposes. You can use the same product key regardless of which version is selected and used for install.
nitewulf
Honorable Member
Thread Author #3
Jessica,
I realize that going from 32 to 64 is considered a clean install. I guess my question was that even though I've used a 32 bit disk and key to install Windows 7, I can now use the other 64 bit disc and key to perform a full, custom install of 64 bit over the 32 bit version.
If the key is indeed the same for both versions, will I have to convince Microsoft that I made a mistake and really wanted 64 bit or will it just install and activate?
JessicaD
Jessica,
You shouldn't have a problem -- just install and activate. If you do have a problem (which, again, I highly doubt) just post back and we can help you from there.
