mahindra1234
- Joined
- Dec 19, 2011
Hi Guys,
I have this below requirement in my application. I have to connect to windows 2003 server machine using 'remote desktop connection' from windows 7 system.
I am getting the below warning, while I am connecting, I must be able to disable this warning as there would be no user intervention in production environment.
Warning: The publisher of this remote connection can not be identified. Do you still want to connect anyway?
I am using this below command at the command prompt to connect to windows 2003 server from my windows 7 embedded standard system.
mstsc.exe <.rdp file location> /admin
If i dont use the .rdp file in the command, I am not getting the above warning. But I must use the .rdp file in the command as it contains some parameters
required.
Could some one please suggest me, how i can disable this warning even after using the .rdp file in the command.
please find below the .rdp file for your refernce.
screen mode id:i:2
use multimon:i:0
desktopwidth:i:1024
desktopheight:i:768
session bpp:i:32
winposstr:s:0,3,0,0,800,600
compression:i:1
keyboardhook:i:2
audiocapturemode:i:0
videoplaybackmode:i:1
connection type:i:2
displayconnectionbar:i:1
disable wallpaper:i:1
allow font smoothing:i:0
allow desktop composition:i:0
disable full window drag:i:1
disable menu anims:i:1
disable themes:i:0
disable cursor setting:i:0
bitmapcachepersistenable:i:1
full address:s:isp
audiomode:i:0
redirectprinters:i:1
redirectcomports:i:0
redirectsmartcards:i:1
redirectclipboard:i:1
redirectposdevices:i:0
redirectdirectx:i:1
autoreconnection enabled:i:1
authentication level:i:0
prompt for credentials:i:0
negotiate security layer:i:0
remoteapplicationmode:i:0
alternate shell:s:
shell working directory:s:
gatewayhostname:s:
gatewayusagemethod:i:4
gatewaycredentialssource:i:4
gatewayprofileusagemethod:i:0
promptcredentialonce:i:0
use redirection server name:i:0
username:s:standbyuser
password 51:b
Thanks
Rahul
required.
screen mode id:i:2
use multimon:i:0
desktopwidth:i:1024
desktopheight:i:768
session bpp:i:32
compression:i:1
keyboardhook:i:2
connection type:i:2
disable themes:i:0
full address:s:isp
audiomode:i:0
redirectdirectx:i:1
alternate shell:s:
gatewayhostname:s:
password 51:b
Thanks
Rahul
