1. Microsoft has announced the release of the Windows 10 Technical Preview. Read more...
Windows 7 Mirror's Edge not working on x64
Discussion in 'Windows Games' started by nicasoft, Jan 22, 2009.
  1. nicasoft
    nicasoft New Member
    Jan 12, 2009
    6
    mine wont even install....
    even in compatibility with vista...
    E8400
    4870 512mb
    4gbs ram
    win7 B7000 x64
  2. bboy500
    bboy500 New Member
    Jan 16, 2009
    204
    i had no trouble at all in regular mode. on windows 7 32 bit tho.
  3. penguin17
    penguin17 New Member
    Nov 8, 2008
    12
    Mine installed no probs on win7 64bit, didn't try anything different, installed it as i would any other game.
  4. SLiM PiCKiNS
    SLiM PiCKiNS Member
    Jan 20, 2009
    88
    i will attempt to install this game as soon as i can get a copy and i will let u know what happens. i'm also running win7 x64
  5. Sonic
    Sonic New Member
    Jan 13, 2009
    80
    Mine installed without any problems. Hmm...unless...yes, of course. Do this:
    1.Click the Start button [​IMG], click All Programs, and then click Accessories.
    2.Right-click Command Prompt, and then click Run as administrator. [​IMG] In the User Account Control window, verify that Program name is Windows Command Processor, and then click Yes.
    3.In the Administrator: Command Prompt window, type or paste the following text at the prompt: reg delete HKLM\SOFTWARE\Microsoft\SQMClient\Windows\DisabledSessions /va /f
    4.Press Enter to install the solution.
    5.If The operation completed successfully displays, close the Administrator: Command Prompt window to complete this procedure.
    That's the solution for the installer. It should install now.;)
  6. SLiM PiCKiNS
    SLiM PiCKiNS Member
    Jan 20, 2009
    88
    what exactly does deleting that registry entry do? just curious. i'm not too familiar with comps but i just want to have an idea of what i'm doing before i attempt it. thanks.
    ok got it to work in compatability mode xp sp2, installed everything normally, just changed the mirrorsedge exe file to compatability xp sp2 and it runs fine now.
  7. Pepper Wadlow Esq
    Pepper Wadlow Esq Banned
    Jan 18, 2009
    68
    This is that game with the thin red-headed Asian girl, right? Tell me, is it possible to have sex with her in this game? It seems that it is a first person mode and you would be the girl - so having sex with it would be like masturbating instead of having sex with it.
    Edit: I just realized this is the demo version and there is probably little chance that they would let you have sex with it. Afterall, if they let you have sex with it right away what would be the point in spending part of your gov't check on the game. Silly me. Still, I would like someday to have sex with it.
  8. BenGrimm84
    BenGrimm84 New Member
    Feb 3, 2009
    2
    Same Issue
    So, I have been having the same issue, I'm using the x64 version of 7 with:
    Core 2 Quad Q8200
    XFX nForce 680i LT mobo
    4 GB Corsair XMS RAM
    Sony DRU-842A ATA DVD-RW
    (edit: EVGA GeForce 8600GT graphics card. Dual Monitor Setup)
    Mirror's Edge will not install properly, nor will other games, including Lost Planet Colonies, and Farcry 2. I tried installing it right after installing Windows 7, I tried doing so after I installed the Vista x64 drivers for the chipset, audio etc. and I have also noticed that it has been having a hard time with compressed files of all types, including multipart .rar, and .cab files. I tried removing the reg key as in the instructions, but the cmd window would not allow it, so I went into regedit and removed it manually... I have also tried installing the files after turning off UAC, after switching the setup.exe file to XP compat mode, with administration rights, and in various combinations.
    I'm about out of options, and I would greatly appreciate any help. thanks in advance.
  9. DRen72
    DRen72 New Member
    Jan 10, 2009
    48
    Ran fine here.
    I installed and played Mirror's Edge on Windows 7 64-bit using ATi drivers v9.1.
    I did not encounter any problems whatsoever. Played the entire game through.
  10. NateBritish
    NateBritish New Member
    Apr 11, 2009
    2
    Solution Mirrors Edge Windows 7
    For this to work go to the Mirrors Edge C:\Users\Nate\Documents\EA Games\Mirror's Edge\TdGame and open TdEngine or search TdEngine in Windows 7.
    Find ResX= and ResY=
    Set these to your monitors native resolution for example mine had to be set to ResX=1920
    ResY=1080
    That's it! Now it works perfect of course I installed the Patch 1.01, crack 1.01 from gamecopyworld and the latest Nividia PhysX drivers.
    P.S. No need to run in Compatability mode
  11. Vedichi
    Vedichi New Member
    May 10, 2009
    2
    Cant move?!
    Installed on win 7 64 bit and first time i played i could walk normally and play the game fine, then after a while the movement keys stopped working. I checked out the control setting panel and all the keys were blanked out, and they stay that way even when i try to restore to defaults. That is the go to defaults, i exit settings, enter settings and back to blank?! what could this be?
  12. mirr73
    mirr73 New Member
    Jul 20, 2011
    4
    [langtitle=sr]Re: Mirror's Edge not working on x64[/langtitle]
    [lang=sr]koristio sam prijedlog od NateBritish ali kada razbijem staklo ili se razbije staklo u mojoj okolini(kada ga specijalci razbiju)igra mi se toliko uspori da izgleda kao da se teleportiram deset metara a napravim samo jedan korak
    IMALI NETKO RIJEĊ ENJE!!!!!!!!!
    [/lang]
  13. mirr73
    mirr73 New Member
    Jul 20, 2011
    4
    Re: Solution Mirrors Edge Windows 7
    CAN ANYONE HELP ME!! i installed the game normally and found those resy and resx and changed them and it worket but when i play it and break a glass the game slowes down amd i have a felling that faith is teleported 10 steps after i only did 1 step
    patch 1.01 included
    HELP PLEASE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Share This Page
