RyanBaskett
Member
Has anyone ever heard of a carrying case for a custom build PC? I'm not talking about the PC case itself but like a bag with wheels or something for a PC, for means of transportation. I Googled 'Mid-Tower PC Carrying Cases' but just found a lot of PC cases themselves. Does anyone know if something like this exists? If it does I would really like to know where I can get one! Thanks! :)
I don't think that you will find a ready made case like you described, but then you aren't very specific. I think the best you could do is to improvise something yourself. For rollers, I would recommend Lian Li WB-01 or WB-02 rollers. As far as the enclosure, you could use a simple cover for local storage. If you wanted something for transport purposes, probably the easiest thing would be to craft a wooden case. You could even pad it in a fashion to protect against impact.
Jimbo22
I don't know of any personally, but I have seen custom handles as after market hardware, so one can carry the case more easily. I also seen platforms with wheels, kinda like a furniture moving dolly at the local office supply store...eg OfficeMax and Staples. That are specifically designed for PC's.
seekermeister
Honorable Member
Trouble
Noob Whisperer
I've seen some of these Link Removed
made from a nylon webbing type material which appear to be adjustable.
badrobot
This is the most presentable transporter that you can get. It's compact and foldable. It's actually a luggage trolley. You just need some padding as shock absorbers for your PC.
Or this one if your CPU will fit (you can get the frame separately) :
An image from 'Carrying case for Mid Tower?'. Compact, navy blue rolling cart with three wheels and a retractable handle.
RyanBaskett
Member
Sweet! Thanks guys! That gives me some new ideas. I would say the closest thing so far to what I was imagining was this one: (See Attached) but I like the idea of a padded wooden case as well. I think that shouldn't be too hard to make.
RyanBaskett
Member
I am thinking probably a second carrying case similar to the one that holds the desktop PC and if you are getting really creative, they will both be interior padded hard shell cases much like a guitar case with the double skateboard wheels. :)))
