xanhellx
-..for example, in my music folder, i use to have all the albums with their respective artwork, just naming as "folder" the picture of the album cover in vista. not it seems it doesn't work. i'm using windows 7 RC. everythings working fine, even DREAMSCENE :P
x
x
x
JessicaD
Xanhellx,
It's great that you are enjoying Windows 7 so much! Just in case you haven't heard, you can now pre-order your copy of Windows 7 for a discounted price of more than half off! For more information, see the Windows 7 Pre-Order offer page here: Link Removed
Jessica
Microsoft Windows Client Team
reghakr
Hello and welcome
Did you copy over your folders after installing?
Was it a "clean" install or an upgrade.
Look in your music folders and verify that you have files named AlbumArt ******.jpg or simply folder.jpg.
ahd55
I had the same problem.
Microsoft fixed this problem with build 7127 just upgrade and your problem solved. :)
