This WindowsForum thread discusses a registry tweak intended to streamline renaming JPEG files to "folder.jpg" for organizing large media libraries. The original poster shares a download link (later removed) and updates with a Google Code project that includes an uninstall option. Followers express appreciation, with one asking about automating folder icon customization, leading to explanations about converting images to ICO files and replacing folder icons. Overall, the thread reflects helpful community support for media organization tasks.
ahd55
If you have a large media library this tweak will be very useful.
I have a large media library and I like to organize it for faster browsing with a covers, ablum art, poster ...etc
I tend to rename pictures (only jpg files) to folder.jpg a lot this tweak will add an option to rename it to folder.jpg to save some time :).
Download
Link Removed due to 404 Error
I tried it in windows 7 it might work in Vista.
Re: Awesome!
........Is there any chance you could write a tweak that would do the same thing but set the picture as the actual folder icon so you don't have to have the folder icon around the picture?
Or is there another way of doing this?
Thanks
You'd need to convert your image to an icon (.ico) file which would contain (at minimum) 256x256, 64x64, 48x48, 32x32, 24x24 and 16x16 sized True Colour images. IcoFX is a free icon program that could do this in "batches".
It would then be a matter of swapping each folder icon over.
reghakr
That's a great registry tweak,
If the extension of the picture is ,jpg, you would need to alter the registry script slightly:
Windows Registry Editor Version 5.00
[HKEY_CLASSES_ROOT\jpgfile\shell\Set as a Cover]
[HKEY_CLASSES_ROOT\jpgfile\shell\Set as a Cover\command]
@="cmd.exe /c rename \"%L\" folder.jpg"
In my case, when I navigate in Regedit to the HKEY_CLASSES_ROOT, I find my Default association is ACDSEE.jpg.
Therefore I modified it for that
[HKEY_CLASSES_ROOT\ACDSee.JPG\shell\Set as a Cover]
[HKEY_CLASSES_ROOT\ACDSee.JPG\shell\Set as a Cover\command]
If your association is with another graphic editor, just navigate to that key and look for the default value, and substitute that for jpgfile.
mediocremusic
download
this sounds like what i've been searching for all day. is it still possible to download it? none of the links are working.
ahd55
Thread Author #4
here is the rapidshare premium link (you don't need a RS account)
Link Removed - Invalid URL
epi
Awesome!
Thanks so much mate this saved me a lot of time!
Thanks
Elmer
Re: Awesome!
Thanks
