Yomaster
Hey, everyone. I've been scouring the net looking for an effective weather clock screensaver for Windows 7, but can't seem to find one. I'm looking for one similar to the iPad app, which can be seen here:
I'm not a big Apple fan, but I know someone who has an iPad and saw them running this app. Then, I got to thinking, "Wouldn't that be a nice screensaver?" :D
Anyone know of such a screensaver for Windows 7? Thanks!
It seems you are searching for a weather clock screensaver for Windows 7 that is similar to the one you saw on an iPad app. While I can't access the specific link you mentioned, I can suggest a few alternatives or ways to achieve a similar effect on Windows 7. Here are a couple of suggestions: 1. Use Weather Apps with Full-Screen Mode: You can consider using weather apps like YoWindow, Desktop Weather, or The Weather Channel Desktop. Although these are not exactly screen savers, they provide real-time weather updates with beautiful visuals and can run in full-screen mode, simulating a screensaver-like experience. 2. Custom Screensaver Creation: If you have a specific design in mind, you might want to explore tools that allow...
It seems you are searching for a weather clock screensaver for Windows 7 that is similar to the one you saw on an iPad app. While I can't access the specific link you mentioned, I can suggest a few alternatives or ways to achieve a similar effect on Windows 7. Here are a couple of suggestions: 1. Use Weather Apps with Full-Screen Mode: You can consider using weather apps like YoWindow, Desktop Weather, or The Weather Channel Desktop. Although these are not exactly screen savers, they provide real-time weather updates with beautiful visuals and can run in full-screen mode, simulating a screensaver-like experience. 2. Custom Screensaver Creation: If you have a specific design in mind, you might want to explore tools that allow you to create custom screensavers. There are various software like InstantStorm or Axialis Screensaver Producer that enable you to design and customize your own screensavers, including weather and clock elements. 3. Widgets and Gadgets: Another option is to use desktop widgets or gadgets that display weather information. Gadgets like WeatherBug or AccuWeather can be placed on your desktop to show weather information in real-time. While the exact screensaver you are looking for might not be readily available for Windows 7, these alternatives can help you achieve a similar visual effect or functionality. Let me know if you need further assistance or have any specific requirements in mind!
