The thread discusses choosing between different Dell Inspiron Mini 10 batteries, focusing on capacity and power specifications. The original poster asks whether a higher mAh rating or a 24Wh battery offers better performance, and contributors clarify that higher mAh typically means longer battery life, with the 5200mAh battery likely providing around 56Wh. Ultimately, the poster decides to order the 5200mAh battery based on the advice.
rickluc
Well-Known Member
Battery for a Dell Inspiron Mini 10 has two options for a battery; 6 cell, 11.1 volt, 4400mah, lithium-ion and a 6 cell, 11.1 volt, 5200mah, lithium-ion. Is the latter just a little more capacity or too much power? Thanks
I think its just the way companys print out the specs of the batteries. If my memory serves me right the 5200mah should give you about 56wh battery life so I would go for the 5200mah battery. But to be sure just google it.
rickluc
Well-Known Member
Thread Author #2
A friend with a glass came up with this K916P, 11.1 volts, 24wh, M456P 71776. Is the 24wh more capacity than a 4400mah and/or 5200mah? Thanks
rickluc
Well-Known Member
Thread Author #4
Hey thanks. So what about the 24wh? Is it bigger and better? Or will the 5200mah do me well? Thanks
Paul Simpson
rickluc
Well-Known Member
Thread Author #6
Thanks, got it ordered.
