Brokas
Hello, i'm building my own gaming PC. List of the parts:
Processor: AMD Phenom II X4 955 Black Edition
VGA: AMD Radeon Sapphire HD 5850 1024MB
RAM Memory: DDR3 16GB (2x 8GB) 1600MHz
Motherboard: Gigabyte 970a-d3 AM3
Psu: PowerX3 Pro Edition 800W Psu
Hard drive: WD HDD SATA 500GB 7200RPM 6GB/S/16MB
Case: Enermax LuxuRay ECA-3190Series
Monitor: LED Samsung S22B300B
DVD+/-RW
Logitech wireless mouse and keyboard.
Since it's my first time building custom gaming pc, i want to know if the parts are right? Will i'll be able to use my pc with this build? Also if you got any suggestions tell me. Early thanks.
It seems like you have a good selection of components for your gaming PC build. Let's review each part to ensure they are compatible and suitable for your build:
  • Processor:
  • The AMD Phenom II X4 955 Black Edition is a quad-core processor, which should be fine for gaming at mid-range settings.
  • VGA (Graphics Card):
  • The AMD Radeon Sapphire HD 5850 1024MB is an older graphics card but should still be capable of running games at lower to medium settings depending on the game.
  • RAM Memory:
  • DDR3 16GB (2x 8GB) 1600MHz is a good amount of RAM for gaming. Just make sure your motherboard supports DDR3 memory.
  • Motherboard:
  • The Gigabyte 970A-D3 AM3 motherboard is compatible with the AMD Phenom II X4...
  • Processor:
  • RAM Memory:
  • Motherboard:
  • The Gigabyte 970A-D3 AM3 motherboard is compatible with the AMD Phenom II X4 955 processor. It supports DDR3 RAM and should work well with your other components.
  • PSU (Power Supply):
  • The PowerX3 Pro Edition 800W PSU should provide enough power for your components. Ensure it has the necessary connectors for your motherboard and graphics card.
  • Hard Drive:
  • The WD HDD SATA 500GB 7200RPM should be sufficient for storing games and other data. Consider adding an SSD for faster boot times if your budget allows.
  • Case:
  • The Enermax LuxuRay ECA-3190Series case should accommodate your components. Make sure it has good airflow for cooling.
  • Monitor:
  • The LED Samsung S22B300B is a decent monitor choice for gaming.
  • DVD+/-RW:
  • This optical drive is optional but handy if you need to install software from discs.
  • Input Devices:
  • Logitech wireless mouse and keyboard are personal preferences and should work fine with your build.
    Suggestions:​
  • Graphics Card: Consider upgrading to a more modern GPU for better gaming performance.
  • Storage: Add an SSD for faster system boot times and game loading.
  • Processor: If budget allows, consider upgrading to a newer processor for better performance. Overall, your build should work, but consider the upgrade suggestions for better gaming performance. Double-check compatibility and make sure all parts fit in the case. Good luck with your build!
