twistedvincent
Why is it that my 500g external HD now reads "375GB free of 465GB" and my external terabyte HD reads "788GB free of 931GB"? I'm missing 35GB from one drive and almost 70Gb from the other!! Where did it go and how can I get it back??
The solution is probably something simple that I'm overlooking. :confused:
Thanks in advance for any help.
When you see discrepancies in the available storage on your external hard drives, it's essential to understand how storage capacities are calculated and where the missing space might have gone. Here are a few reasons for the differences you are seeing:
  • Decimal vs. Binary System:
  • Computers use a binary system (base-2) to store data. However, storage manufacturers use a decimal system (base-10) to advertise storage capacities.
  • The actual storage available on a drive will always be less than the advertised capacity because of this difference in counting systems.
  • File System Overhead:
  • File systems like NTFS, FAT32, or exFAT reserve some space for their structures which reduces the usable capacity of the drive...
  • This overhead is essential for the file system to manage files and directories efficiently.
  • Hidden Files and System Restore Points:
  • Hidden files, system files, and system restore points can take up space on the drive that might not be immediately visible.
  • Temporary files and cache can also consume space.
  • Formatting and Partitioning:
  • When you format a drive, some space is used for the file system itself.
  • If the drive is partitioned, each partition will also have its own file system overhead.
    How to Reclaim Missing Space:​
  • Check Hidden Files and Folders:
  • Show hidden files on your external hard drives to see if there are any large hidden files taking up space.
  • Delete Temporary Files:
  • Use disk cleanup tools to delete temporary files, cache, and unnecessary system files.
  • Empty the Recycle Bin:
  • Make sure to empty the recycle bin on the external drives.
  • Check for System Restore Points:
  • System restore points can take up considerable space. You can manage them through the System Protection settings.
  • Run Disk Cleanup:
  • Use the built-in Disk Cleanup tool in Windows to clear out unnecessary files.
  • Check Disk Health:
  • Run disk diagnostic tools to ensure the health of your drives. Sometimes issues with the drive can cause space discrepancies. By following these steps and understanding the factors that contribute to the differences in available space, you should be able to identify and reclaim some of the missing storage on your external hard drives.
