JohnMartin1408
Hey Guys,My name is John Martin and here i'm facing some problem regarding Reset Cisco Wi-Fi Password If some Know how to fix this problem please guide me i'm facing this problem from last 10 days.I try that step by step process but unfortunately unable to solve.
Hello John. If I understand your problem well, here is what to do : with the router powered, reach to the back of it with a stiff wire, and poke into the small hole with it for +/- 10 seconds until the front LEDs blink. This will reset the router to factory, all setings are gone includind the PW.
daopa
Fantastic Member
