RyanBaskett
Member
Hi there, we have an Asus GeForce GTX 780 GPU and are interested in installing a liquid cooling system to the card, myself and my other techs have not installed one before and are hoping for a strong recommendation on which would be the best performance wise for this particular graphics card. How is a liquid cooling system installed onto a GPU? Thank you for any assistance you may be able to provide us.
Ryan
Now days you can order a GPU with the water block pre-mounted, it's a bit more pricey but no added labor and stress of adding one to an existing GPU. It attached pretty much like a CPU water block....
After that you'll need to build your water loop, which consists of a water pump, reservoir, tubing, fittings and the coolant itself.
Jimbo22
RyanBaskett
Member
So if I am ordering:
7/16" ID / 5/8" OD XSPC HighFlex tube, what size compression fitting do I need?
