The thread discusses how to save documents in LibreOffice to a folder on the Windows 11 desktop. The original poster asks for guidance after struggling to find the option, and the response provides detailed, step-by-step instructions on how to save files directly to the desktop or specific folders there. Overall, the conversation is helpful and informative, aiming to assist with file-saving procedures in LibreOffice on Windows 11.
NGDRB
Active Member
Does anyone know how to save documents in the application "LibreOffice" to a folder on my desktop? I have tried googling the problem as well as trying to find it in LibreOffice's help section, but for some reason I cannot find it. I am running Windows 11 Home. Thank you in advance.
To save documents in LibreOffice to a folder on your desktop, you can follow these steps:
  • Open LibreOffice: Launch the LibreOffice application you want to use, such as Writer or Calc.
  • Create or Open a Document: You can either create a new document by clicking on “File” and then selecting “New” or open an existing document by going to “File” and then “Open.”
  • Saving the Document:
  • Once you have your document ready, go to the File menu at the top left corner.
  • Click on Save As. This option allows you to specify where you want to save the document.
  • Navigate to the Desktop:
  • In the "Save As" dialog window, look for the left sidebar where you can quickly access different locations...
  • Select Desktop from the list of locations. If it’s not visible, you can also navigate to Desktop by clicking on “This PC” or “My Computer” and finding your Desktop folder.
  • Choose a Folder (Optional):
  • If you want to save it in a specific folder on your Desktop (and not just on the Desktop itself), navigate to that folder.
  • Name Your File: Enter a name for your document in the “File Name” field.
  • Select File Format:
  • In the “Save as type” dropdown, choose the desired file format (e.g., ODT for LibreOffice documents, DOCX for Microsoft Word compatibility, etc..
  • Click Save: After selecting your desired location, naming your file, and choosing the correct format, click the Save button.
Now your document should be saved in the chosen Desktop folder.
Troubleshooting Tips:
  • Make sure you have permission to write to the Desktop folder. Sometimes, user account settings or security software can interfere with saving files.
  • If you encounter any specific error messages, feel free to provide those for further assistance.
    If you have any other questions or need clarification, let me know!
