The thread discusses the original poster's search for a reliable digital camera around $100, emphasizing the importance of macro capabilities for close-up photography. The conversation explores the limitations of point-and-shoot cameras for macro use, with advice suggesting they may not be suitable for detailed close-up shots, and recommending considering DSLR options for better macro performance—though at a higher cost. The overall sentiment indicates the poster is leaning towards a Fuji camera based on macro test results but is concerned about warranty issues from non-authorized sellers.
seekermeister
Honorable Member
Since it appears that my old camera has gone partially inop, I'm thinking of buying another. However I used the old one so little, that I didn't learn much that is of use in buying something else. I want one that is reliable as possible with a good warranty of a good name brand, at a price of ~$100.
There are so many variables to consider, I don't know where to start. One thing lacking in my old camera is a release cable, because the camera doesn't have any provision for attaching it...does any digital camera?
After only spending a couple of minutes scanning eBay returns, I came across this one:
http://www.ebay.com/itm/Nikon-CoolP...451550?pt=Digital_Cameras&hash=item51b8b8859e
but can I do better?
EDIT: Another important factor for me is how to determine just how close the camera can be to the subject and focus properly? For instance, getting a clear shot of a small computer component.
seekermeister
Honorable Member
Thread Author #22
Okay, with the camera issue settled, I'm now looking for a case. I noticed that you called your case a half case, and in the picture it doesn't appear that it will fully enclose the camera. I would prefer one that does, and be made of genuine leather, not PU leather. The problem there is that the ones that I've found so far cost more than my old camera did, which seems inordinately expensive. Don't suppose you know of anything that would fit my taste and budget...do you?
badrobot
seekermeister
Honorable Member
Thread Author #24
It will look awesome with a carbon fiber finish than leather I think. Just wrap it around with carbon fiber adhesive sheets. The kind that is used as car skins.
At first glance, I was confused by this, because I thought you were responding to my last post about a case. But then I realized that you are speaking a a replacement for the red skin on the camera instead. Yes, I could envision that material covering the camera and looking quite good, but without a precise pattern, I don't believe I could make it work. Also, the fact that the thickness is specified as being 1.5 - 4mm makes it appear than the variation in thickness might leave high spots along the edge, like a waffle.
EDIT: Don't know about the camera, but I ordered a couple of sheets of that material, which I will probably use on some other project.
badrobot
seekermeister
Honorable Member
Thread Author #27
Yes, when I spoke with the tech rep on the phone earlier, we discussed the lens operation some. He also mentioned that the QX-1, which is apparently the new replacement, also has a power switch, rather than being powered on by the lens. He didn't say it, but I would imagine that also means that the zoom function is now powered on it also. The only other difference that he mentioned about it was that it was a bit lighter.
badrobot
seekermeister
Honorable Member
Thread Author #29
Thanks, I could have gone for a while without seeing that.
EDIT: Then again, maybe it is a good thing. Amazon always brags about their easy returns...maybe I could just refuse shipment of the red one, and then order the black one instead. I have no idea if Amazon would charge me restocking and shipping fees or not?
seekermeister
Honorable Member
Thread Author #30
I got a response from Amazon about refusing the shipment and reordering the black camera. They said that if I refused the shipment, I wouldn't be charged for the shipping fee. They didn't mention anything about a restocking fee. I would order the black one now, but I think I'll wait until the other arrives, so I will know that it is being returned. It is being sent via FedEx Smartpost, so it will be delivered by USPS. I seriously doubt that it could fit into my little mail box, but since I don't know how it will be packaged, I can't be certain.
seekermeister
Honorable Member
Thread Author #31
hmm, I just checked some of the negative reviews on the camera, and they are giving me second thoughts:
The fact that there are some common complaints about the camera is bad enough, but the story related in the longer review, regarding the hassle that Fuji gave him covering the repair under warranty is worse.
badrobot
seekermeister
Honorable Member
Thread Author #33
I can understand that, but I've found that most feedback/reviews are written when the person first receives it, and only reflects their first impression. Obviously, one can't only consider negative reports, because as you say, there will always be some who are just unfortunate. It's difficult to strike a balance and weigh an average, but even though I found only one account of the experience with warranty support, that one speaks very loudly. I still haven't made up my mind, I'm still mulling it over.
badrobot
seekermeister
Honorable Member
Thread Author #35
I like the caution sign you added to your signaturebar photo. Is it a self-reminder? :)
seekermeister
Honorable Member
Thread Author #36
Since I have several days before needing to make a decision, I'm going to continue shopping some. Perhaps it's a futile effort, but I'm wondering if there are any other cameras of similar abilities and price?
badrobot
badrobot
seekermeister
Honorable Member
Thread Author #39
I noticed that you only looked at the 4 & 5 star ratings on the XF-1, but the 22% consisting of 3 stars and below is quite significant in my mind. Also the fact that one reviewer ordered 4 cameras of this model and all 4 had identical defects (lens control error), makes this camera look quite iffy. The problem is that the cameras that I've looked at that doesn't appear to have problems as such, are above my price range.
Even if I decided to pay more, I still wouldn't know which to buy, because I'm uncertain what factors control the ability to obtain quality macros?
badrobot
