The thread discusses the original poster's search for a reliable digital camera around $100, emphasizing the importance of macro capabilities for close-up photography. The conversation explores the limitations of point-and-shoot cameras for macro use, with advice suggesting they may not be suitable for detailed close-up shots, and recommending considering DSLR options for better macro performance—though at a higher cost. The overall sentiment indicates the poster is leaning towards a Fuji camera based on macro test results but is concerned about warranty issues from non-authorized sellers.
seekermeister
Honorable Member
Since it appears that my old camera has gone partially inop, I'm thinking of buying another. However I used the old one so little, that I didn't learn much that is of use in buying something else. I want one that is reliable as possible with a good warranty of a good name brand, at a price of ~$100.
There are so many variables to consider, I don't know where to start. One thing lacking in my old camera is a release cable, because the camera doesn't have any provision for attaching it...does any digital camera?
After only spending a couple of minutes scanning eBay returns, I came across this one:
http://www.ebay.com/itm/Nikon-CoolP...451550?pt=Digital_Cameras&hash=item51b8b8859e
but can I do better?
EDIT: Another important factor for me is how to determine just how close the camera can be to the subject and focus properly? For instance, getting a clear shot of a small computer component.
seekermeister
Honorable Member
Thread Author #41
I appreciate your values, but you don't mine. As I stated at the outset, I don't use a camera a lot, therefore I'm not into photography in the fashion that you are. All of the good things about this camera are what I want, but I also require reliability in product and warranty (also stated in the OP). It is beginning to look that a camera meeting my requirements don't exist that I can afford, so I don't know where I stand.
edit: the guy who bought 4 units with lens error probably didn't read about how to turn the camera on. The power switch is the lens itself.
After viewing the short video attached to that review, demonstrating the error, I think you might be right about him, but I'm less sure about the rest of those types of reviews. I understand that the power is controlled at the lens, but if that power isn't turned on, then the LCD wouldn't be powered on either...would it?
seekermeister
Honorable Member
Thread Author #42
I came across an ad that interested me, but I haven't studied it out, and it may not be the right camera at all. The thing that caught my eye is that it is a SLR for only $300 (hard to think I just said only $300, because that is 3 times more than I started out planning to pay)
It has a lot of zoom and the focus range starts at 17.7", so it should do okay with macros....yes/no?
Here it is a little cheaper:
badrobot
badrobot
seekermeister
Honorable Member
Thread Author #45
It's not a priority, but the reason that the zoom interested me on the HS 35 is that I thought it would be good to get distance shots of my vehicle at about 125 feet, in case anyone was messing around it. Of course, that would probably only be necessary at night, and requiring IR, but I did see some filters once that were supposed to support IR. Would 30 x zoom get fine enough details of a person's face for legal identification?
badrobot
seekermeister
Honorable Member
Thread Author #47
You can turn on the LCD to view the photos you took by just pressing the "play" button. You DON't have to turn the whole system on through the lens.
It's hard to judge by the video attachment on the review with the 4 "defective" cameras, because it was taken too closely to see how he was turning it on, but that may well be the reason for his problems, but it can't be for others, because they were accepted and repaired under warranty, and I can't imagine Fuji accepting frivolous claims
seekermeister
Honorable Member
Thread Author #48
If it is on a tripod, yes. The longer the zoom, the shakier and trickier the focus gets. If it has optical stabilization, sometime it works.
I have nothing else to add here. The item you are asking me about is not the one that I would think about getting myself. Plus, you keep changing your mind about what you want to use it for. Define what you want and stick to it. Otherwise, you will not get anywhere wasting your own time. If you want something that does everthing, get a DSLR body, get a macro lens, a zoom lens and an all around fast lens and get ready to pay at least $3000.
Cheers!
A little tolerance please. If I knew exactly what I wanted, I wouldn't have to ask questions. :)
badrobot
seekermeister
Honorable Member
Thread Author #50
It's not that you can't answer questions outside of your interests, it's that you prefer not to. You may not know all cameras, but I'm quite sure that you know most, if not all of their functions. Still, I can appreciate a need for focus of discussions. I'll try to rein myself in.
badrobot
seekermeister
Honorable Member
Thread Author #52
Everything breaks. You just need to decide which one you want to break.
If I were to break it, that would be one thing, but buying a camera prone to breakage is another.
Nice collection.
seekermeister
Honorable Member
Thread Author #54
That may be true, but reading is preferable to groping in the dark. After all, I'm reading your posts aren't I?
badrobot
Yup, but you listen more to people like this: :)
An image from 'Digital Camera'. An elderly person uses a digital camera to take a photo at an event broadcasted in Russia.
seekermeister
Honorable Member
Thread Author #58
Typical of observations made by those who feel that anyone, that doesn't automatically agree with them, must be wrong.
Jimbo22
That's just funny right there, I don't care who your are...That's just damned good TV!!!!! :ahaha:
