The thread discusses a Silverlight error on Windows 7 that prevented watching Netflix videos, which was resolved by adjusting folder permissions for C:\ProgramData\Microsoft\PlayReady to grant the user full control. The original poster recommends checking permissions if reinstallation and deleting certain files don't work. A later contributor mentions that running the browser with admin rights initially helped, and installing the correct version of a related file for AMD x64 systems also fixed the issue.
GomJabbar
Something happened and I could no longer watch videos on Netflix due to the above error (on a Windows 7, 64-bit machine). Googling, I discovered this is a Silverlight error. Tried uninstalling and reinstalling Silverlight, but that made no difference. Also tried deleting the file C:\ProgramData\Microsoft\PlayReady\mspr.hds as I had read in some guides, but that didn't solve the issue either.
What finally worked was changing permissions on the following folder. I had to give my user full control.
Before changing permissions, I would try reinstalling Silverlight and deleting mspr.hds first. But if that doesn't work for you, check the permissions on the PlayReady folder.
Libertarian
I granted my browser admin rights, and now it works. Good idea for browser to have admin rights? Probably not.
Further research shows MS has another version of this file for AMD x64 PCs. I installed the AMD version and it now works fine.
microsoft dot not com damit because this forum won't let me post links to microsoft /en-us/download/confirmation.aspx?id=36501
