ToddeSwe
Hi!
I want to connect my TV, Media Player and XBox to my routed network.
I have ONE connection to use in my livingroom where all this gadgets are and i'm now wondering what to use, a Switch or one more router?
My network knowledge is very poor as you can tell by the question. :)
Thanks in advanced:
ToddeSwe
a switch is pretty much plug and go, if you use a second router you'll need to set it up as a bridge, the only advantage of using a router would be ability to use bridge via wireless to save having wires...but in the same instance, wireless is worse in just about every aspect than a hard wire connection. Personally would go with a switch.
Highwayman
ToddeSwe
Hi and thanks! I did buy a Level One Switch, hope it will do the job well. :)
ToddeSwe
