The thread discusses how to run Perl script B independently and asynchronously from Perl script A on Linux, ensuring script A does not wait for B to finish. The suggested solution is to append an '&' to the command to run script B in the background, with alternative methods like using fork or Proc::Background for broader compatibility. Overall, users are providing practical advice to achieve independent execution of scripts.
kalyanbl
Hi folks,
Within Linux I would like Perl script A to launch Perl script B. However, I want script A to continue running without waiting for script B to return.
And I would like B to be totally independent so that when script A ends, script B is still running.
Is this possible? Any suggestion would be appreciated!
Thank you
Kalyan bl
Linux developer
You can append an & at the end of your second script launch like this:
system("/script/myscript.sh $params &");
Or if your running one of this distros that won't let that work you'll have to use fork or Proc::Background.
Josephur
Windows Forum Admin
Josephur
Windows Forum Admin
Your welcome,
If your script is going to be mass distributed between different possible distributions I highly recommend learning fork.
