The thread discusses enterprise Azure modernization in 2026, emphasizing selective movement from IaaS to managed PaaS while retaining VMs for legacy or specialized workloads. Contributors identify App Service, managed databases, Functions, AKS when justified, monitoring, security, governance, AI, and DR services as potentially high-ROI, while stressing FinOps, tagging, policy, IaC, landing zones, and unified hybrid management to control costs and complexity. Overall sentiment is positive but pragmatic: Azure offers strong scalability and operational benefits, though migration difficulty, cost sprawl, Kubernetes skills, monitoring, compliance, and multi-region governance remain significant challenges.
Hi everyone,
I’m researching how enterprises are modernizing their IT environments using Microsoft Azure Infrastructure and Platform Services (IaaS + PaaS) in 2026.
How are organizations balancing AI scalability, cybersecurity, hybrid cloud governance, disaster recovery, Kubernetes/container management, and multi-region performance optimization while still keeping Azure costs under control?
I’d also love to know:
  • Which Azure services are currently delivering the best ROI?
  • Are companies moving more workloads toward PaaS instead of traditional VM-based infrastructure?
  • What challenges are you facing with Azure migration, monitoring, compliance, or automation?
  • Which best practices or tools are helping reduce operational complexity?
Looking forward to hearing real-world enterprise experiences and recommendations from IT professionals and Azure architects.
Hi talktoaliveallen,
As of May 2026, the strongest enterprise Azure pattern I’m seeing is not “move everything to Azure,” but modernize selectively: keep VM/IaaS where control, legacy compatibility, or licensing demands it; move application platforms, data, security, monitoring, and automation toward managed PaaS wherever possible.
Big-Picture Enterprise Pattern​
Most mature Azure environments are optimizing around the Azure Well-Architected Framework pillars:
  • Reliability
  • Security
  • Cost Optimization
  • Operational Excellence
  • Performance Efficiency
That framework is still the best lens for balancing AI scale, security, governance, DR...
  • Reliability
  • Security
  • Cost Optimization
That framework is still the best lens for balancing AI scale, security, governance, DR, containers, and cost.
Useful Microsoft references:
Services Commonly Delivering Strong ROI​
In enterprise environments, the best ROI usually comes from services that reduce operations, standardize governance, or remove infrastructure management.
  • Azure App Service: strong ROI for web apps and APIs that do not need full Kubernetes complexity.
  • Azure Functions / Logic Apps: good for event-driven automation, integration, and lightweight workflows.
  • Azure SQL Database / Azure SQL Managed Instance: often better ROI than self-managed SQL Server VMs when patching, HA, backups, and scaling are considered.
  • Azure Kubernetes Service: good ROI when there is genuine container platform demand, but poor ROI if used for simple apps that App Service could handle.
  • Azure Monitor / Log Analytics / Application Insights: high operational value, but must be governed carefully because log ingestion can get expensive.
  • Microsoft Defender for Cloud: useful for security posture management, vulnerability visibility, and regulatory alignment.
  • Microsoft Sentinel: valuable for SOC/SIEM use cases, but cost depends heavily on ingestion strategy.
  • Azure Arc: strong for hybrid governance across on-prem, edge, and multicloud resources.
  • Azure Policy / Azure Landing Zones: high ROI because they prevent expensive misconfiguration at scale.
  • Azure Backup / Azure Site Recovery: good ROI for DR standardization, especially where older DR processes are manual or inconsistent.
  • Azure OpenAI / Azure AI Foundry-related services: strong business ROI when tied to real use cases, but GPU/model/token/data costs need tight governance.
Are Companies Moving from IaaS to PaaS?​
Yes, but selectively.
The common path is:
  • Lift-and-shift to Azure VMs for speed or datacenter exit.
  • Stabilize using Azure Monitor, Backup, Defender, Policy, Update Manager, and Cost Management.
  • Modernize the highest-value apps to PaaS, containers, or serverless.
  • Retain IaaS for workloads with OS-level dependencies, legacy middleware, special licensing, or complex migration risk.
In other words, enterprises are not abandoning VMs. They are trying to reduce the percentage of workloads that require VM-level administration.
Good candidates for PaaS:
  • Web apps
  • APIs
  • Integration services
  • Databases with standard patterns
  • Internal line-of-business applications
  • Event processing
  • Reporting and analytics workloads
Less obvious candidates:
  • Legacy ERP
  • Low-latency monoliths
  • Apps needing custom drivers
  • Apps with hard-coded server assumptions
  • Third-party software certified only on VMs
AI Scalability Approach​
For AI workloads, the better enterprise designs separate experimentation, production inference, and data governance.
Recommended approach:
  • Use separate subscriptions or resource groups for AI experimentation and production.
  • Apply budget alerts and quotas before giving teams GPU capacity.
  • Use autoscaling for inference workloads where possible.
  • Use Azure AI services or managed model endpoints before building custom GPU clusters.
  • Use AKS or Azure Machine Learning compute only where the workload truly requires custom orchestration.
  • Keep sensitive data behind Private Link, managed identities, and strict RBAC.
  • Monitor token usage, GPU hours, storage growth, and data movement separately.
The biggest AI cost mistakes are usually idle GPU resources, excessive logging, duplicated datasets, and uncontrolled experimentation.
Cybersecurity and Governance​
The stronger enterprise Azure environments usually standardize on a few controls:
  • Deploy an Azure Landing Zone model.
  • Use management groups to separate platform, production, non-production, sandbox, and regulated workloads.
  • Enforce guardrails with Azure Policy.
  • Use Microsoft Entra ID, conditional access, PIM, and managed identities.
  • Enable Defender for Cloud for posture management.
  • Use Private Link, private endpoints, and hub-spoke or Virtual WAN networking where appropriate.
  • Centralize logs into a governed monitoring/SIEM strategy.
  • Use infrastructure as code so security settings are repeatable.
Important: Many Azure security problems are not caused by missing tools. They are caused by inconsistent ownership, too many exceptions, and unclear subscription boundaries.
Hybrid Cloud Governance​
Hybrid is still very common, especially in regulated industries, manufacturing, healthcare, finance, and large enterprises with datacenter dependencies.
Typical pattern:
  • Use Azure Arc to project on-prem servers, Kubernetes clusters, and some multicloud resources into Azure governance.
  • Use Azure Policy for consistent configuration.
  • Use Defender for Cloud for security posture.
  • Use Azure Monitor for operational visibility.
  • Use Azure Local or Azure Stack-style architectures where workloads need local execution.
  • Use ExpressRoute for predictable private connectivity where latency, reliability, or compliance requires it.
The goal is not always full cloud migration. The goal is one governance and operations plane.
Disaster Recovery and Multi-Region Design​
Enterprises are becoming more careful here because multi-region designs can double or triple cost if done blindly.
Common approach:
  • Classify apps by RTO and RPO.
  • Use Availability Zones before multi-region if regional failure tolerance is not required.
  • Use Azure Backup for baseline protection.
  • Use Azure Site Recovery for VM-level DR.
  • Use database-native replication for critical data platforms.
  • Use active-passive multi-region for most business-critical apps.
  • Use active-active only when the business truly needs it.
  • Test failover regularly, not just during audits.
Best cost control: do not give every workload the same DR design. A tiered DR model saves a lot of money.
Kubernetes and Containers​
AKS is excellent when used for the right reasons.
Good AKS use cases:
  • Microservices at scale
  • Multi-team platform engineering
  • Complex deployment patterns
  • Service mesh requirements
  • Custom sidecars or operators
  • Batch and AI workloads
  • Multi-container application platforms
Poor AKS use cases:
  • One or two simple web apps
  • Teams without Kubernetes skills
  • Apps that could run on App Service
  • Workloads without clear scaling or deployment requirements
For AKS cost control:
  • Use separate node pools by workload type.
  • Right-size VM SKUs.
  • Enable cluster autoscaler.
  • Use horizontal pod autoscaler.
  • Use Spot nodes only for fault-tolerant workloads.
  • Set CPU and memory requests/limits.
  • Use Azure Policy for AKS guardrails.
  • Review Log Analytics and Container Insights ingestion.
  • Use reservations or savings plans for predictable node usage.
Cost Control Practices That Actually Work​
The best Azure cost programs are usually a mix of FinOps, automation, and architecture discipline.
Recommended controls:
  • Use Microsoft Cost Management budgets and alerts.
  • Require resource tagging for owner, environment, app, cost center, and data classification.
  • Use Azure Advisor recommendations regularly.
  • Use Reservations for stable workloads.
  • Use Savings Plans for flexible but predictable compute spend.
  • Use Azure Hybrid Benefit where Windows Server or SQL Server licensing allows it.
  • Shut down dev/test resources automatically.
  • Use autoscale instead of overprovisioning.
  • Review unattached disks, public IPs, snapshots, idle gateways, and unused App Service Plans.
  • Treat logging as a costed architecture decision, not an unlimited default.
A good rule: optimize architecture before negotiating discounts. Discounts help, but they do not fix wasteful designs.
Common Challenges Enterprises Face​
The most common pain points I see are:
  • Migration discovery is incomplete before planning starts.
  • Apps are moved to VMs and then never modernized.
  • Landing zones are built after workloads are already deployed.
  • Logging costs grow faster than expected.
  • AKS is adopted without enough platform engineering maturity.
  • Security teams and cloud teams disagree on ownership.
  • Compliance evidence is manual instead of policy-driven.
  • DR exists on paper but is rarely tested.
  • Teams use too many SKUs, regions, and architectures without standards.
  • Automation exists, but each team writes its own version.
Tools That Reduce Operational Complexity​
The most useful stack for enterprise Azure operations:
  • Azure Landing Zones for standardized foundations.
  • Azure Policy for guardrails.
  • Bicep or Terraform for infrastructure as code.
  • Azure DevOps or GitHub Actions for deployment automation.
  • Azure Monitor for platform and app telemetry.
  • Application Insights for application performance.
  • Defender for Cloud for posture and workload protection.
  • Microsoft Sentinel for SIEM/SOAR where required.
  • Azure Update Manager for patching.
  • Azure Backup / Site Recovery for protection and DR.
  • Azure Arc for hybrid control.
  • Azure Advisor and Cost Management for optimization.
Practical Recommendation​
If I were advising an enterprise Azure modernization program in 2026, I’d suggest this order:
  • Build or fix the landing zone first.
  • Define workload tiers for security, DR, performance, and cost.
  • Move commodity apps toward PaaS.
  • Keep legacy workloads on IaaS only where justified.
  • Use AKS as a platform, not as a default hosting choice.
  • Put FinOps controls in place before AI/GPU expansion.
  • Centralize governance with Policy, Defender, Monitor, and Arc.
  • Automate repeatable deployment through IaC and CI/CD.
  • Review cost, security, reliability, and performance monthly.
  • Treat modernization as a continuous program, not a one-time migration.
My short answer: the best ROI comes from reducing operational burden, not simply reducing VM count. PaaS, automation, policy-driven governance, and disciplined FinOps are where most enterprises get the biggest long-term gains.
Mark Mckinney
Active Member
Hi everyone,
FFDS
Hi everyone,
In 2026, enterprises are using Microsoft Azure’s Infrastructure as a Service (IaaS) and Platform as a Service (PaaS) to build more intelligent, secure, and flexible IT environments. The focus is no longer just on moving workloads to the cloud but on using cloud services in smarter ways.
Using Azure for AI Innovation
Many organizations are adopting AI-powered applications for customer service, data analysis, forecasting, and business automation. To support this, they are increasingly choosing Azure PaaS services because they provide built-in scalability, security, and management features. Azure’s AI and data services help businesses develop and deploy AI solutions faster without spending time managing infrastructure.
At the same time, IaaS remains important for organizations that need greater control over virtual machines, specialized applications, or legacy systems. Companies are therefore combining IaaS and PaaS to achieve the right balance between flexibility and efficiency.
Strengthening Security
Cybersecurity continues to be a top priority. Enterprises are implementing a “defense-in-depth” approach, which means protecting systems at multiple levels, including identity, networks, storage, and applications. Azure’s security capabilities help organizations monitor threats, enforce access controls, encrypt data, and maintain compliance requirements.
Many businesses are also adopting security-by-default practices, ensuring that protection is built into the platform rather than added later. This reduces risks and improves resilience against cyberattacks.
Expanding Hybrid Cloud Strategies
Not every workload is moving entirely to the public cloud. Many organizations continue to operate a mix of on-premises systems, Azure cloud services, and edge environments. This hybrid cloud approach allows businesses to meet regulatory requirements, improve performance, and maintain control over critical data.
Azure enables companies to manage these environments from a unified platform, making governance, monitoring, and resource management more efficient. Hybrid cloud also supports AI workloads by allowing organizations to place applications where they perform best.
Hi Mark,
Looks like FFDS and the duplicated quote may have been accidental, but your summary is heading in the right direction. I’d add a bit more emphasis on cost governance, PaaS selection, and operational maturity, because those are where enterprise Azure projects usually succeed or fail.
Key Additions I’d Make​
1. PaaS Is Growing, But IaaS Is Not Going Away​
Enterprises are definitely moving more workloads to PaaS, especially for:
  • Web apps
  • APIs
  • Databases
  • Event-driven workloads
  • AI-enabled business applications
But IaaS remains important for:
  • Legacy applications
  • Custom OS dependencies
  • Lift-and-shift migrations
  • Specialized enterprise software
  • Workloads with strict licensing or compatibility needs
The best strategy is usually modernize where practical, retain IaaS where justified.
2. Best ROI Azure Services​
Commonly high-ROI Azure services in enterprise environments include:
  • Azure App Service for web/API hosting without VM management
  • Azure Functions for event-driven automation
  • Azure SQL Database / Managed Instance for managed database operations
  • Azure Monitor + Application Insights for visibility and troubleshooting
  • Microsoft Defender for Cloud for posture management and threat protection
  • Azure Policy for governance at scale
  • Azure Arc for hybrid and multicloud management
  • Azure Backup / Azure Site Recovery for DR and resilience
  • Azure Kubernetes Service when container scale justifies the complexity
  • Microsoft Cost Management + Azure Advisor for ongoing optimization
3. Cost Control Is Now a Design Requirement​
The big mistake is treating cost optimization as an afterthought. Enterprises should build it into architecture from day one.
Recommended steps:
  1. Define budgets per subscription, workload, and environment.
  2. Require tagging for owner, app, cost center, and environment.
  3. Use Azure Policy to prevent non-compliant deployments.
  4. Use reservations or savings plans for predictable compute.
  5. Shut down dev/test resources automatically.
  6. Review Log Analytics ingestion regularly.
  7. Right-size VMs, AKS node pools, App Service Plans, and databases.
  8. Use Azure Advisor recommendations monthly.
4. AKS Should Be Used Carefully​
AKS can deliver strong value, but only when the organization has real container platform needs.
Good AKS use cases:
  • Microservices
  • Multi-team container platforms
  • AI/ML batch workloads
  • Complex deployment pipelines
  • Service mesh or advanced orchestration needs
Poor AKS use cases:
  • A simple web app
  • A single API
  • Workloads better suited to App Service or Container Apps
5. Hybrid Cloud Is About Unified Governance​
Hybrid cloud is not just “some workloads on-prem and some in Azure.” The goal is unified control.
Enterprises are using:
  • Azure Arc for managing servers, Kubernetes, and hybrid resources
  • Azure Monitor for centralized observability
  • Defender for Cloud for security posture
  • Azure Policy for compliance enforcement
  • Microsoft Entra ID for identity consistency
Short Takeaway​
The strongest enterprise Azure strategy in 2026 is:
Use PaaS where it reduces operational burden, keep IaaS where control is required, govern everything through policy and identity, and make cost optimization part of the architecture — not a cleanup task later.
Mark Mckinney
Active Member
Hi everyone,
Hi everyone,
From what I’m seeing in enterprise environments, Azure adoption in 2026 is increasingly focused on platform modernization rather than simply lifting and shifting VMs to the cloud. Many organizations are moving toward Azure PaaS services because they reduce infrastructure management overhead and allow teams to focus more on innovation and business outcomes.
The Azure services delivering the strongest ROI tend to be Azure Kubernetes Service (AKS), Azure SQL Managed Instance, Azure App Service, Azure OpenAI Service, Azure Functions, and Microsoft Fabric. These services help reduce operational effort while improving scalability, reliability, and performance.
For AI workloads, enterprises are using a combination of Azure OpenAI, AKS, and scalable data platforms to support growing demands. At the same time, cybersecurity remains a top priority, with organizations relying on Microsoft Defender for Cloud, Microsoft Sentinel, Zero Trust architectures, and identity governance through Microsoft Entra ID.
Regarding infrastructure strategy, yes, there is a noticeable shift from traditional VM-based deployments to PaaS and container-based architectures. While VMs are still important for legacy applications, many new applications are being built on Azure App Service, AKS, Functions, and managed databases because they offer better scalability and lower maintenance requirements.
The biggest challenges I continue to see include:
Legacy application migration complexity
Cost management and resource sprawl
Multi-region governance and compliance
Kubernetes operational skills gaps
Monitoring distributed applications
Data residency and regulatory requirements
To reduce operational complexity, successful organizations usually implement:
Infrastructure as Code (Terraform or Bicep)
Azure Monitor and Application Insights for observability
FinOps practices for cost optimization
Automated backup and disaster recovery using Azure Site Recovery
Landing Zone architectures for standardized deployments
Hi Mark,
That is a solid summary. I would add two important qualifications.
AKS Is Not Automatically High ROI​
AKS delivers strong ROI when an organization has multiple containerized workloads and a capable platform team. For simpler applications, Azure App Service, Functions, or Container Apps often provide better ROI with less operational overhead.
Current AKS cost controls include:
  • AKS Automatic and node auto-provisioning
  • HPA, VPA, KEDA, and cluster autoscaling
  • Managed Prometheus instead of excessive Container Insights ingestion
  • Resource requests, limits, and namespace quotas
  • Spot nodes for interruptible workloads
  • Reservations or savings plans for predictable capacity
Disaster Recovery Must Match the Service​
Azure Site Recovery primarily protects VM-based and on-premises workloads. PaaS applications require service-native DR features, such as:
  • Database geo-replication or failover groups
  • Zone- or geo-redundant storage
  • Azure Front Door or Traffic Manager
  • Repeatable deployments using Bicep or Terraform
  • Documented and regularly tested failover and failback procedures
Each workload should have business-approved RTO and RPO targets. Multi-region active-active architecture should be reserved for workloads that genuinely justify its cost.
Landing Zones and AI​
Microsoft’s current guidance says enterprises generally do not need a separate AI landing zone. AI services can be deployed into standard application landing zones while inheriting existing identity, networking, policy, security, and cost controls.
Overall, the successful pattern is:
  1. Establish Azure Landing Zones and governance.
  2. Modernize suitable workloads to PaaS.
  3. Retain VMs for justified legacy requirements.
  4. Use AKS only where Kubernetes adds measurable value.
  5. Implement FinOps and observability controls before scaling AI.
  6. Test security and DR processes rather than treating them as documentation exercises.
The real ROI comes from reduced operational effort and faster delivery, not merely replacing VMs with newer services.
