Two desktop gaming PCs sit side by side, one air-cooled and one glowing with RGB liquid cooling.
Walk into almost any PC-building forum or scroll through a "first gaming rig" parts list today, and you would be forgiven for thinking that an all-in-one (AIO) liquid cooler is as mandatory as thermal paste. Somehow, the PC hardware world drifted from treating liquid cooling as an enthusiast luxury to acting as though bolting a tower of aluminum fins onto a modern processor will immediately turn your Windows desktop into a toaster oven.
In a pointed reality check published by How-To Geek, veteran PC builder Monica J. White argued that AIO liquid coolers simply do not make sense as the default choice for most PCs anymore. She is not declaring war on radiators—in fact, she runs an AIO in her own rig—but her core point hits a nerve that every Windows PC builder ought to examine: between vastly improved dual-tower air coolers, realistic gaming workloads, and the extra mechanical baggage that liquid loops introduce, most users are paying more for cooling headroom they will never use.
Two desktop gaming PCs sit side by side, one air-cooled and one glowing with RGB liquid cooling. The Great CPU Heat Panic: TDP vs. Real-World Windows Gaming​
Part of the industry's liquid-cooling reflex comes from how modern processors behave—and how AMD's dominant X3D gaming chips get talked about online. Modern desktop CPUs are engineered to boost aggressively until they hit either a power limit or a thermal ceiling. On AMD's AM5 lineup, that maximum operating temperature (Tjmax) is 95°C across the Ryzen 9000 family, which can alarm builders who grew up expecting a healthy CPU to idle at fridge temperatures and peak in the sixties.
Looking closely at the actual specifications reveals why one-size-fits-all cooling advice falls apart:
  • AMD Ryzen 7 9700X: An 8-core, 16-thread Zen 5 chip with a 65W default TDP and boost clocks up to 5.5 GHz. On its official spec sheet, AMD explicitly states: "Premium air cooler recommended for optimal performance."
  • AMD Ryzen 7 9800X3D: An 8-core, 16-thread gaming powerhouse with a 120W default TDP and boost clocks up to 5.2 GHz. Here, AMD's spec sheet shifts to: "Liquid cooler recommended for optimal performance."
  • AMD Ryzen 9 9950X3D: A 16-core, 32-thread flagship built for both gaming and content creation, sporting a 170W default TDP and up to 5.7 GHz boost—and again carrying AMD's recommendation for a liquid cooler for optimal performance.
There is an important technical caveat here that cuts both ways. First, default TDP is not a direct measurement of real-world wattage in every workload. AMD's own documentation notes that boost sustainability depends on thermal conditions, motherboard power limits, and the application being run. In Gamers Nexus's AM5 cooler test suite, for example, sustained stress workloads pulled roughly 157W on the 9800X3D and 276W on the 9950X3D—well above their nominal TDP badges.
Second, however, a gaming PC is not a 24/7 synthetic stress test. As White observed in How-To Geek, most Windows games do not hammer all CPU cores at maximum power draw for hours on end. Frame rendering typically puts heavier, more sustained pressure on your graphics card while the CPU experiences burstier, lighter loads. Treating a mid-range or even an 8-core gaming chip as if it permanently sits at 276W is like buying a semi-truck radiator for a commuter hatchback.
Section Summary: While AMD officially recommends liquid cooling for its 120W and 170W X3D flagships and a premium air cooler for the 65W Ryzen 7 9700X, real-world Windows gaming rarely resembles a sustained all-core power torture test.
Dual-Tower Air Coolers Grew Up While Nobody Was Looking​
If your mental picture of air cooling is still stuck in 2012—complete with flimsy mounting clips, buzzing 92mm fans, and thermal shutdowns during a summer heatwave—it is time for an update. Air coolers have gotten shockingly good, and competition in the budget dual-tower market has completely changed the math.
Two names dominate budget value discussions for good reason: the Thermalright Peerless Assassin 120 (a 6-heatpipe dual-tower cooler frequently found around $40 to $45) and its newer sibling, the Thermalright Phantom Spirit 120 (which bumps the count to 7 heatpipes and typically sells in the $45 to $65 range depending on the variant). Neither requires a pump, tubing, or radiator mounting space, yet both punch dramatically above their weight class.
Independent lab data backs up the resurgence of air cooling—while also drawing a clear boundary around where liquid still pulls ahead. In Gamers Nexus's 26-cooler comparison on its AM5 platform (updated with 9800X3D and 9950X3D data in 2026), testers measured thermals in a hemi-anechoic acoustic chamber with fan speeds noise-normalized to a quiet 25 dBA at one meter, alongside 100% fan-speed runs:
  • Best Overall: Gamers Nexus gave its top overall crown to an air cooler—the $60–$70 Sudokoo SK700 / SK 700V, a single-fan tower packing seven 6mm heatpipes that held 64.1°C over ambient at 25 dBA on the 157W 9800X3D workload (and 60.9°C Tdie at 31.9 dBA at full speed). The ID-Cooling A720 air cooler took runner-up.
  • Best Noise-Normalized Air: The $149.95 Noctua NH-D15 G2 (specifically the Low Base Convexity variant tuned for AMD's flatter heat spreader) led the ID-Cooling A720 and be quiet! Dark Rock Pro 5 by 1–2°C on the 9800X3D. Even more tellingly, on the punishing 276W 9950X3D noise-normalized test, the NH-D15 G2 averaged 69.4°C over ambient (roughly 90°C total) and was the only air cooler in the test suite to finish without thermal throttling or a thermal trip.
  • Best Noise-Normalized Liquid: The $250–$300 Tryx Panorama 360 topped the liquid chart at 53.6°C over ambient on the 157W 9800X3D test, roughly 10.5°C cooler than the single-fan Sudokoo tower—though at roughly four times the price, largely thanks to its built-in 6.5-inch AMOLED display.
Gamers Nexus also highlights an inconvenient truth for anyone overspending on cooling: as CPU heat load drops, the temperature gap between high-end coolers shrinks rapidly. On moderate workloads, buying an oversized cooler mainly lets you run fans slower and quieter rather than unlocking dramatic thermal breakthroughs.
Cooler TierRepresentative ModelsTypical PriceBest FitKey Trade-off
Entry Single-Tower AirThermalright Assassin Spirit V2~$1665W CPUs, budget office/light gaming PCsLacks headroom for high-wattage chips
Value Dual-Tower AirThermalright Peerless Assassin 120 / Phantom Spirit 120~$40–$65Most mainstream & gaming builds (9700X, 9800X3D)Needs ~157mm case clearance; check RAM height
Flagship Dual-Tower AirNoctua NH-D15 G2~$150Quiet-focused high-end builds, heavy workloadsExpensive; 168mm height & 32mm default RAM clearance
Budget 360mm AIOID-Cooling FX 360 Pro / Thermalright Frozen Prism 360~$50–$55Tight tower clearance, aesthetic blackout buildsCheaper build quality; long-term liquid longevity questions
Flagship 360mm AIOTryx Panorama 360 / Arctic Liquid Freezer III~$100–$300Sustained 250W+ workloads (e.g., 9950X3D rendering)Higher cost, pump noise/failure points, 360mm radiator space
Section Summary: Modern $40–$70 dual-tower air coolers easily handle typical gaming loads, while flagship air designs can even survive heavy AM5 stress tests—leaving expensive 360mm AIOs mostly fighting for the top 10°C of sustained extreme-wattage headroom.
The Frame-Rate Myth: Colder Doesn't Automatically Mean Faster​
Here is where marketing hype collides with physics: dropping your CPU temperature from 76°C to 64°C does not magically hand you 20 extra frames per second in Cyberpunk 2077 or Call of Duty.
Think of CPU cooling as a pass/fail threshold rather than a linear performance slider. Yes, modern processors use temperature-aware boost algorithms like AMD Precision Boost 2, so avoiding thermal throttling matters. If your CPU is pinned at 95°C and slashing clock speeds to protect itself, upgrading from an inadequate cooler will restore lost performance.
Once your processor is running comfortably below its thermal limit and holding its intended boost clocks, however, throwing another $150 at an AIO radiator yields diminishing-to-zero gaming returns. Most modern PC games hit a GPU bottleneck long before a well-cooled 8-core processor breaks a sweat. For budget-conscious Windows builders, redirecting $100 from a flashy liquid cooler into a faster graphics card tier, an extra NVMe SSD, or better system memory will deliver infinitely more real-world speed.
Section Summary: Cooling exists to keep a CPU below its throttling threshold so it can hit target boost clocks; once it is comfortably there, liquid cooling will not buy extra gaming frame rates.
Simplicity, Acoustics, and What Can Actually Go Wrong​
Let's be fair to liquid coolers: the internet horror stories claiming AIOs inevitably burst and drown your GPU are wildly overblown. Modern closed-loop coolers are reliable enough that catastrophic leaks are rare edge cases.
Still, engineering complexity is engineering complexity. A tower air cooler is refreshingly primitive: a copper coldplate, heatpipes, stamped aluminum fins, and one or two standard fans. Nothing evaporates, nothing corrodes internally, and if a fan bearing starts rattling five years from now, you unclip it and swap in a $15 replacement in five minutes without touching your thermal paste.
An AIO, by contrast, introduces a pump, rubber tubing, seals, a radiator, and liquid coolant. Pumps wear out over time, coolant slowly permeates through tubing over years of service, and Gamers Nexus specifically flags long-term internal buildup or "gunking" as an ongoing consideration for liquid coolers—especially at the ultra-budget $50 end of the market where corners are cut on materials and quality control.
Nor does buying an AIO guarantee a whisper-quiet Windows PC. White noted that her own AIO remains noticeably loud even when the system is barely working, a reality backed up by acoustic testing. Liquid coolers still rely on fans pushing air through dense radiator fins, plus you add the mechanical hum or high-pitched whine of a pump (something Gamers Nexus explicitly noted on units like the Arctic Liquid Freezer III). Meanwhile, front-mounting an AIO can also reduce airflow directly over your motherboard's VRM heatsinks compared to a large air cooler's fans blowing air right across the socket area.
Section Summary: Air coolers eliminate pump wear, permeation, and rare leak risks altogether, and neither cooling style is automatically quieter—pump hum and radiator fan pressure can make an AIO louder than a tuned air tower.
When an AIO Still Makes Complete Sense (And How to Choose)​
Calling out the "AIO-by-default" habit does not mean liquid cooling is obsolete. It simply belongs back in the category where it shines: specialized builds with specific physical or thermal requirements.
Before you hit "checkout" on your next Windows build or upgrade, run through this practical four-step checklist:
  1. Audit your actual workload, not your worst-case fantasy. If your PC spends 90% of its life gaming, browsing, and running everyday Windows apps on a 65W–120W class chip like the Ryzen 7 9700X or 9800X3D, a $40–$70 dual-tower air cooler is the sweet spot. If you regularly run hours-long Blender renders, 4K video exports, or heavy code compiles on a 16-core 9950X3D pushing 250W+, a 280mm or 360mm AIO earns its keep.
  2. Measure your case and RAM clearance first. Large dual-tower air coolers are chunky—Thermalright's Phantom Spirit 120 EVO stands 157mm tall, while Noctua's NH-D15 G2 hits 168mm with 32mm of default front-fan RAM clearance. If you are building in a compact chassis or small-form-factor case without room for a tall heatsink, an AIO is often the cleaner physical fit.
  3. Compare noise-normalized data, not 100% fan charts. Anyone can make a cooler look great on a chart by spinning its fans like a jet engine. Check noise-normalized benchmarks (like 25 dBA or 35 dBA testing) so you know how loud a cooler actually gets to achieve its temperatures.
  4. Be honest about aesthetics. If you want an unobstructed view of your motherboard, RGB memory, or a 6.5-inch LCD screen showing animated GIFs inside your tempered glass panel, buy the AIO and enjoy it—just buy it because you want the look, not because someone convinced you your CPU will melt without it.
AIOs are optional for most modern PCs—neither pointless nor unsafe, just dramatically overprescribed. Unless your CPU regularly chews through workstation-class wattage or your case simply lacks the room for aluminum fins, a great air cooler lets you keep your money, skip the pump anxiety, and put your budget where your Windows games will actually feel it.
  1. AIO liquid coolers don't make sense for most PCs anymore How-To Geek 2026-11-26T19:30:15+00:00
  2. thermalright.com thermalright.com
  3. bestbuy.com bestbuy.com
