What PCWorld recommends
PCWorld splits its picks into plain hubs, desk docks, Thunderbolt docks and DisplayLink docks, and they aren't interchangeable. These are PCWorld's judgments. They are not an independent ranking.
- Best overall: Anker 555 8-in-1 USB-C Hub. PCWorld describes a weighty metal-and-polycarbonate build... or rather, in its own words, a solid aluminum and polycarbonate design with two 5Gbps USB-A ports, a 5Gbps USB-C data port, a separate USB-C power-input port, SD and microSD slots, Ethernet and HDMI. It accepts up to 100W of input but passes 85W to the laptop. PCWorld says it replaces the earlier Anker 7-in-1 pick by adding Ethernet and 60Hz HDMI. It lists an 18-month warranty and a carrying pouch.
- Budget pick: Hiearcool USB-C Hub. It is basic: two USB-A ports, SD and microSD, and one HDMI port limited to 4K at 30Hz. It accepts up to 100W of charging input and has no Ethernet. PCWorld says it is fine for a single 1080p or 1440p monitor.
- Budget runner-up: OWC USB-C Travel Dock. Compact, with a hidden cable that PCWorld finds a bit short. The tested 5-in-1 version had two USB-A ports, Ethernet, HDMI and USB-C charging input. PCWorld notes OWC has since added an SD slot at a slightly higher price.
- Premium: Monoprice 13-in-1 Dual-HDMI + DP MST Dock. It drives two 4K displays (one at 60Hz, one at 30Hz) over a 10Gbps USB-C link using compression built into modern laptops. It has five USB-A ports, two HDMI 1.2 ports and DisplayPort, and no USB-C ports. It has a power jack and fed up to a tested 87W to the laptop.
- Premium runner-up: Dockcase Smart USB-C Hub 10-in-1 Explorer Edition. It has a small LCD that shows what is connected to each port. PCWorld calls the interface clunky and says there is essentially no manual.
- DisplayLink runner-up: Plugable USB-C Triple 4K HDMI Docking Station (UD-6950PDZ). It supports three 4K displays. PCWorld warns that DisplayLink's compressed data shares a 10Gbps link, so heavy video and storage loads can degrade.
Prices and promotions on the live page change often. PCWorld's rule of thumb is $30 to $40 for a good hub, perhaps more with tariffs, and over $100 for a docking station. Check current pricing before you buy. The page also says PCWorld may earn commission on purchases made through its links. PCWorld says this doesn't affect its editorial independence.
The compatibility checklist
1. Count your ports
List the USB-A peripherals, card readers, Ethernet needs and monitors you actually use. A mouse, keyboard and printer already take three USB-A ports.
2. Check how your laptop charges
If the laptop has one USB-C port and uses it for charging, you need a hub with a dedicated power-input port. Check that the input wattage matches the laptop's needs. PCWorld notes that Windows laptops typically warn about a slow charger when power is short. Microsoft's own documentation says Windows can show a "Device is charging slowly" message when the charger is underpowered, incompatible, or plugged into a non-charging port.
3. Don't assume USB-C means video
This is the biggest trap. PCWorld says USB-C ports are poorly labeled and you must check the laptop manual for DisplayPort Alt Mode support. Microsoft's documentation backs this up. The connector can support alternate modes such as DisplayPort. Which mode is used is decided by the connector's driver and firmware, not by Windows itself. PCWorld's testing shows the real-world effect: a Surface Book 2 with an 8th-gen Core chip gave no output through the Monoprice dock, while 2022-onward Samsung and Surface laptops with 12th- and 13th-gen Core chips worked.
4. Match the dock class to your displays
PCWorld's guidance:
| Need | Suggested class |
| Printer, mouse, keyboard, SD cards, one or two 1080p displays | Basic 10Gbps USB-C hub |
| Two 4K displays at 60Hz plus fast storage | Thunderbolt dock (40Gbps; 120Gbps with Thunderbolt 5) |
| Several displays for office work, no gaming | DisplayLink dock (needs a driver) |
| Multiple displays via HBR3 with DSC | Works best on 12th-gen Core and newer, per PCWorld's testing |
PCWorld's rule of thumb is that a standard USB-C hub handles two 1080p displays at 60Hz or one 4K display at 30Hz. DisplayLink docks use a Synaptics chip and a software driver. PCWorld says they suit email, Word, Excel and web browsing, and can stutter with high-bitrate video or large transfers. IT admins should confirm that a vendor driver is acceptable in their environment.
PCWorld also says hubs branded for a MacBook Pro, Chromebook or Dell XPS worked on Windows PCs without special software or drivers.
Checking USB4 on Windows 11
If your PC supports USB4 or Thunderbolt, Microsoft documents a built-in check. Since Windows 11 build 22621.1778 (KB5026446), Settings lists attached USB4 hubs and devices and their capabilities.
- Open Settings.
- Go to Bluetooth & devices.
- Select USB, then USB4 Hubs and Devices.
The page appears only when Windows detects a USB4 host router. If it's missing, the system isn't USB4-capable, or the OEM hasn't set up the page. It doesn't tell you whether an ordinary USB-C port supports display output, so you still need the laptop's spec sheet.
If the monitor stays black
PCWorld's guide covers buying, not repair. Community and vendor troubleshooting guides commonly suggest these steps. They are general advice, not PCWorld findings.
- Test the monitor directly on the laptop to find out whether the dock is at fault.
- In Settings > System > Display, use Detect under Multiple displays, or press Win + P and choose Extend.
- Use the dock's HDMI or DisplayPort outputs, not USB-A or data-only USB-C ports.
- Disconnect the dock and its power, wait 15 to 30 seconds, then reconnect it.
- Update the graphics driver, BIOS and dock firmware. A Microsoft Q&A answer suggests holding the power button for 45 to 60 seconds after shutdown to reset a hung USB-C controller. The results are anecdotal.
Heat and trade-offs
PCWorld says hubs can run warm or hot because heat builds up in the circuitry, and suggests a metal-bodied hub to dissipate it. It lists the Dockcase as one that gets warm.
Bottom line
For most Windows users, a modest hub with a separate power-input port, plus a laptop port you've verified for video, covers the job. Spend more only when you need more displays or fast storage, and read the host's port specifications before the hub's box.
- Best USB-C hubs and dongles: Add ports to your laptop or tablet PCWorld · 2022-05-18T07:00:00+00:00
- Best USB-C hubs and dongles 2026: Budget, premium, docks, and more | PCWorld pcworld.com
- FAQ - USB Type-C connector on a Windows system - Windows drivers | Microsoft Learn learn.microsoft.com
